Wildcard SSL certificate renewal failing (NXDOMAIN) - please issue standard certificate for lifeos.quest
Site name: null0090.netlify.app
Custom domain: lifeos.quest (with www.lifeos.quest)
DNS is managed externally at Cloudflare, not Netlify DNS.
I’m getting this error when the certificate tries to renew:
SniCertificate::CertificateValidationError: Unable to verify challenge for *.lifeos.quest: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.lifeos.quest - check that a DNS record exists for this domain
I don’t use any subdomains — everything runs at lifeos.quest and paths under it, no wildcard is needed. Since DNS-01 validation isn’t possible with an external DNS provider, could you please remove the wildcard requirement and reissue a standard (non-wildcard) Let’s Encrypt certificate for lifeos.quest and www.lifeos.quest?
Certificate currently expires Jul 30. Thanks for the help.
