Hi Netlify team,
My TLS certificate renewal is failing for www.northforty.co.uk and the current cert expired Jul 31, so this is time sensitive.
The certificate currently covers a wildcard (*.northforty.co.uk) plus the apex. My DNS is managed externally by 123reg, not Netlify DNS, so the DNS-01 challenge for the wildcard can’t be created and validation fails.
Error from the renewal email:
SniCertificate::CertificateValidationError: Unable to verify challenge for *.northforty.co.uk: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.northforty.co.uk - check that a DNS record exists for this domain
I do NOT need the wildcard. Could you please remove the *.northforty.co.uk wildcard and reissue a standard Let’s Encrypt certificate covering only:
northforty.co.uk
Domain: northforty.co.uk
The exact error message
That DNS is external (123-reg), not Netlify DNS
Request: remove wildcard SAN, reissue standard cert for apex + www
Thanks
G
Update: I’ve since confirmed via Site settings → Domain management that DNS is actually already on Netlify DNS(green “Netlify DNS” checkmark on both www.northforty.co.uk and northforty.co.uk) — not external at 123-reg as I originally wrote. Apologies for the inaccurate detail in my first post; 123-reg is just my registrar, DNS itself is delegated to you.
I also tried removing and re-adding the custom domain to force a fresh, non-wildcard certificate request. That didn’t clear it — the HTTPS panel still shows the certificate scoped to *.northforty.co.uk, ``northforty.co.uk, and I’m now getting a new error on top of the original one:
SSL Provisioning is temporarily disabled because too many recent CertOrder creation with the site.
So this looks like a stuck wildcard certificate record on the account side, not a DNS configuration problem on mine — DNS is correctly on Netlify DNS, and there’s no wildcard alias anywhere in my domain settings.
Could someone from the team please:
- Clear the stuck wildcard CertOrder for
- Reissue a standard (non-wildcard) Let’s Encrypt certificate covering just
www.northforty.co.uk and northforty.co.uk?
This domain has had no valid HTTPS certificate for a month now (expired Jul 31), so I’d really appreciate this getting actioned soon.
