hi, first time here! I have try to build my project from a github repository and it gives me this message:
10:44:01 AM: Netlify Build
10:44:01 AM: ────────────────────────────────────────────────────────────────
10:44:01 AM:
10:44:01 AM: ❯ Version
10:44:01 AM: @netlify/build 29.11.6
10:44:01 AM:
10:44:01 AM: ❯ Flags
10:44:01 AM: baseRelDir: true
10:44:01 AM: buildId: 6478a091330dda08e73fe06c
10:44:01 AM: deployId: 6478a091330dda08e73fe06e
10:44:01 AM:
10:44:01 AM: ❯ Current directory
10:44:01 AM: /opt/build/repo
10:44:01 AM:
10:44:01 AM: ❯ Config file
10:44:01 AM: /opt/build/repo/netlify.toml
10:44:01 AM:
10:44:01 AM: ❯ Context
10:44:01 AM: production
10:44:01 AM:
10:44:01 AM: build.command from netlify.toml
10:44:01 AM:
10:44:01 AM: $ npm run build
10:44:01 AM: > web@0.0.0 build
10:44:01 AM: > tsc && vite build
10:44:05 AM: vite v4.3.8 building for production...
10:44:05 AM: transforming...
10:44:11 AM: ✓ 1089 modules transformed.
10:44:11 AM: rendering chunks...
10:44:11 AM: computing gzip size...
10:44:11 AM: dist/index.html 0.46 kB │ gzip: 0.30 kB
10:44:11 AM: dist/assets/index-55fec1ff.css 11.42 kB │ gzip: 2.26 kB
10:44:11 AM: dist/assets/index-9f9f0fad.js 519.20 kB │ gzip: 171.71 kB
10:44:11 AM:
10:44:11 AM: (!) Some chunks are larger than 500 kBs after minification. Consider:
10:44:11 AM: - Using dynamic import() to code-split the application
10:44:11 AM: - Use build.rollupOptions.output.manualChunks to improve chunking: https://rollupjs.org/configuration-options/#output-manualchunks
10:44:11 AM: - Adjust chunk size limit for this warning via build.chunkSizeWarningLimit.
10:44:11 AM: ✓ built in 6.47s
10:44:11 AM:
10:44:11 AM: (build.command completed in 10.2s)
10:44:11 AM:
10:44:14 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
10:44:14 AM: Failing build: Failed to build site
10:44:14 AM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
10:44:14 AM: Finished processing build request in 26.801s
i try to deploy manually and seems to works fine, its just when a try to do with a github repository, if anyone can help me i appreciate the help, thanks!
