I am trying to deploy my website using netlify. My index.html page is not in the root folder, instead its in the dist folder. I have set the publish directory to dist, however I am still getting an error. i have also added npm run build as the build command, and still nothing.
My deploy log:
4:44:29 PM: Build ready to start
4:44:31 PM: build-image version: 6dfe19d15f524c85d6f9bf7df9fb30b0a9f0a61a
4:44:31 PM: build-image tag: v3.3.10
4:44:31 PM: buildbot version: 6bb3f784302b4ad90de13035b247a363a8bee34a
4:44:31 PM: Fetching cached dependencies
4:44:31 PM: Starting to download cache of 1.3MB
4:44:31 PM: Finished downloading cache in 121.664123ms
4:44:31 PM: Starting to extract cache
4:44:31 PM: Finished extracting cache in 20.859356ms
4:44:31 PM: Finished fetching cache in 143.358671ms
4:44:31 PM: Starting to prepare the repo for build
4:44:32 PM: Preparing Git Reference refs/heads/master
4:44:32 PM: Starting build script
4:44:32 PM: Installing dependencies
4:44:33 PM: v10.20.1 is already installed.
4:44:34 PM: Now using node v10.20.1 (npm v6.14.4)
4:44:34 PM: Attempting ruby version 2.6.2, read from environment
4:44:36 PM: Using ruby version 2.6.2
4:44:36 PM: Using PHP version 5.6
4:44:36 PM: 5.2 is already installed.
4:44:36 PM: Using Swift version 5.2
4:44:36 PM: Started restoring cached node modules
4:44:36 PM: Finished restoring cached node modules
4:44:36 PM: Installing NPM modules using NPM version 6.14.4
4:44:41 PM: > node-sass@4.14.1 install /opt/build/repo/node_modules/node-sass
4:44:41 PM: > node scripts/install.js
4:44:41 PM: Downloading binary from https://github.com/sass/node-sass/releases/download/v4.14.1/linux-x64-64_binding.node
4:44:42 PM: Download complete
4:44:42 PM: Binary saved to /opt/build/repo/node_modules/node-sass/vendor/linux-x64-64/binding.node
4:44:42 PM: Caching binary to /opt/buildhome/.npm/node-sass/4.14.1/linux-x64-64_binding.node
4:44:42 PM: > node-sass@4.14.1 postinstall /opt/build/repo/node_modules/node-sass
4:44:42 PM: > node scripts/build.js
4:44:42 PM: Binary found at /opt/build/repo/node_modules/node-sass/vendor/linux-x64-64/binding.node
4:44:42 PM: Testing binary
4:44:42 PM: Binary is fine
4:44:42 PM: npm
4:44:42 PM: WARN portfolio2020sass@1.0.0 No repository field.
4:44:42 PM: added 235 packages from 163 contributors and audited 654 packages in 5.179s
4:44:42 PM: 4 packages are looking for funding
4:44:42 PM: run npm fund for details
4:44:42 PM: found 1 high severity vulnerability
4:44:42 PM: run npm audit fix to fix them, or npm audit for details
4:44:42 PM: NPM modules installed
4:44:43 PM: Started restoring cached go cache
4:44:43 PM: Finished restoring cached go cache
4:44:43 PM: go version go1.12 linux/amd64
4:44:43 PM: Installing missing commands
4:44:43 PM: Verify run directory
4:44:43 PM: Executing user command: npm run build
4:44:43 PM: npm
4:44:43 PM: ERR! missing script: build
4:44:43 PM: npm
4:44:43 PM: ERR! A complete log of this run can be found in:
4:44:43 PM: npm ERR!
4:44:43 PM: /opt/buildhome/.npm/_logs/2020-05-12T15_44_43_661Z-debug.log
4:44:43 PM: Skipping functions preparation step: no functions directory set
4:44:43 PM: Caching artifacts
4:44:43 PM: Started saving node modules
4:44:43 PM: Finished saving node modules
4:44:43 PM: Started saving pip cache
4:44:43 PM: Finished saving pip cache
4:44:43 PM: Started saving emacs cask dependencies
4:44:43 PM: Finished saving emacs cask dependencies
4:44:43 PM: Started saving maven dependencies
4:44:43 PM: Finished saving maven dependencies
4:44:43 PM: Started saving boot dependencies
4:44:43 PM: Finished saving boot dependencies
4:44:43 PM: Started saving go dependencies
4:44:43 PM: Finished saving go dependencies
4:44:47 PM: Error running command: Build script returned non-zero exit code: 1
4:44:47 PM: Failing build: Failed to build site
4:44:47 PM: Failed during stage âbuilding siteâ: Build script returned non-zero exit code: 1
4:44:47 PM: Finished processing build request in 16.41890585s
can anyone help me with this issue? Thank you
