Hello all
I’m getting strange errors when trying to do production build of gatsby site.
ERROR #98123 WEBPACK.BUILD-HTML
Generating SSR bundle failed
Reading from "node:path" is not handled by plugins (Unhandled scheme).
Webpack supports "data:" and "file:" URIs by default.
You may need an additional plugin to handle "node:" URIs.
File: node:path
Reading from "node:process" is not handled by plugins (Unhandled scheme).
File: node:process
Reading from "node:url" is not handled by plugins (Unhandled scheme).
File: node:URL
not finished Running gatsby-plugin-sharp.IMAGE_PROCESSING jobs - 18.258s
not finished Building HTML renderer - 2.520s
No more information would suggest what the problem is. I spent some time going through various ideas, reinstalled Gatsby CLI, removed node_modules, and removed the package.lock. Nothing helps.
The develop build works fine, site is working as expected, it’s the production build. Just to double check I created a new site in Netlify and it fails with the same errors.
The repo is here https://github.com/jimmylarkin/freedom-moto-web/tree/file-system
Interesting, I just ran into this same thing today.
I wonder if there’s a peer dependency that we both use that is messing with our build…
"dependencies": {
"@emotion/react": "^11.11.1",
"@emotion/server": "latest",
"@emotion/styled": "^11.11.0",
"@mdx-js/mdx": "^2.3.0",
"@mdx-js/react": "^2.3.0",
"@mui/material": "^5.14.12",
"dotenv": "^16.3.1",
"eslint-plugin-react-refresh": "^0.4.3",
"eslint-plugin-storybook": "^0.6.14",
"gatsby": "^5.12.5",
"gatsby-plugin-emotion": "^8.12.0",
"gatsby-plugin-google-analytics": "^5.12.0",
"gatsby-plugin-image": "^3.12.0",
"gatsby-plugin-mdx": "^5.12.0",
"gatsby-plugin-sharp": "^5.12.0",
"gatsby-plugin-sitemap": "^6.12.0",
"gatsby-source-contentstack": "^5.1.0",
"gatsby-source-filesystem": "^5.12.0",
"gatsby-transformer-sharp": "^5.12.0",
"react": "^18.2.0",
"react-dom": "^18.2.0",
"react-markdown": "^9.0.0"
"devDependencies": {
"@storybook/addon-actions": "^6.5.16",
"@storybook/addon-essentials": "^6.5.16",
"@storybook/addon-interactions": "^6.5.16",
"@storybook/addon-links": "^6.5.16",
"@storybook/builder-webpack5": "^6.5.16",
"@storybook/manager-webpack5": "^6.5.16",
"@storybook/node-logger": "^6.5.16",
"@storybook/preset-create-react-app": "^4.1.2",
"@storybook/react": "^6.5.16",
"@storybook/testing-library": "^0.0.13",
"@trivago/prettier-plugin-sort-imports": "^4.2.0",
"prettier": "^3.0.3",
"rimraf": "^5.0.5"
Ah ha! That’s what it was, it’s one of the dependencies, I just don’t know which one just yet.
It’s It’s react-markdown, worked fine with older 8 version.
You are a genius! What’s the solution? Exclude it from webpack config in gatsby-node.js? Or downgrade version?
Downgraded to 8.0.7, and all is good
realarb
November 29, 2023, 5:58pm
7
hello I’ve just run into this issue and don’t know really where it came from?!
As followed my log files from netlify:
error Generating SSR bundle failed
6:56:01 PM: Reading from “node:util” is not handled by plugins (Unhandled scheme).
6:56:01 PM: Webpack supports “data:” and “file:” URIs by default.
6:56:01 PM: You may need an additional plugin to handle “node:” URIs.
6:56:01 PM: not finished Running gatsby.IMAGE_CDN jobs - 49.905s
6:56:01 PM: not finished Building HTML renderer - 3.783s
6:56:03 PM: Failed during stage “building site”: Build script returned non-zero exit code: 2
6:56:02 PM:
6:56:02 PM: “build.command” failed
6:56:02 PM: ────────────────────────────────────────────────────────────────
6:56:02 PM:
6:56:02 PM: Error message
6:56:02 PM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums )
6:56:02 PM:
6:56:02 PM: Error location
6:56:02 PM: In Build command from Netlify app:
6:56:02 PM: npm run build
6:56:02 PM:
6:56:02 PM: Resolved config
6:56:02 PM: build:
6:56:02 PM: command: npm run build
6:56:02 PM: commandOrigin: ui
6:56:02 PM: publish: /opt/build/repo/public
6:56:02 PM: publishOrigin: ui
6:56:03 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
6:56:03 PM: Failing build: Failed to build site
6:56:03 PM: Finished processing build request in 2m24.062s
My package.json:
"dependencies": {
"@fontsource/lato": "^5.0.16",
"@headlessui/react": "^1.7.17",
"autoprefixer": "^10.4.16",
"axios": "^1.5.1",
"firebase": "^10.5.0",
"formik": "^2.4.5",
"framer-motion": "^10.16.4",
"gatsby": "^5.12.4",
"gatsby-plugin-image": "^3.12.1",
"gatsby-plugin-manifest": "^5.12.1",
"gatsby-plugin-matomo": "^0.16.2",
"gatsby-plugin-postcss": "^6.12.0",
"gatsby-plugin-sharp": "^5.12.1",
"gatsby-plugin-sitemap": "^6.12.1",
"gatsby-plugin-web-font-loader": "^1.0.4",
"gatsby-source-wordpress": "^7.12.1",
"gatsby-transformer-sharp": "^5.12.1",
"lodash": "^4.17.21",
"postcss": "^8.4.31",
"react": "^18.2.0",
"react-animations": "^1.0.0",
"react-cookie-consent": "^9.0.0",
"react-helmet": "^6.1.0",
"react-responsive-carousel": "^3.2.23",
"swiper": "^10.3.1",
"tailwindcss": "^3.3.3",
"yup": "^1.3.2"
Can someone please help me further?
