Using redirects to point to /.netlify/images/ results in "must provide the url param"
I’m having a curious issue, because it works perfectly with netlify dev so the config should be correct, but it fails on any deployed sites.
I am trying to use the image cdn to access images stored on another storage service I control.
I would like to avoid using /.netlify/images/ in my URL, so I set up a redirect in my netlify.toml:
[[redirects]]
from = “/image_cdn/*”
to = “/.netlify/images/:splat”
status = 200
force = true
When viewing a URL locally using netlify dev the image is returned, resized as requested:
if I change the root domain in the URL to our production site, without changing any of the params:
{"code":400,"msg":"must provide the url param","error_id":"01K9PVPFHJRP582AKGZVW2JJXS"}
I deployed the changes to netlify.toml on main / my production site, because I know the netlify.toml config is site-wide, including deploy previews.
I can’t figure out what I’m doing wrong, I’ve read and re-read the docs many times, as well as searched on the forum. Given that I’m hosting the files on an external URL, I have no reason to suspect redirect loops or context-specific deployment problems.
Help welcome! Thanks!
Apologies for the delay on this one. Are you still running into this issue?
