Trouble with build, tailwind
Message Deleted
Hello. I’m fairly new to netlify. I’ve deployed a few angular projects, but that’s it. I’m building a simple static site for a client with htmx, native js, and tailwind. When I try to deploy the site on netlify (from github) the build fails. My site’s name is: andrew-a-alderete. I get this error from the netlify build:
8:04:05 PM: Netlify Build
8:04:05 PM: ────────────────────────────────────────────────────────────────
8:04:05 PM:
8:04:05 PM: ❯ Version
8:04:05 PM: @netlify/build 29.51.3
8:04:05 PM:
8:04:05 PM: ❯ Flags
8:04:05 PM: baseRelDir: true
8:04:05 PM: buildId: 66a83bedf33962000821d7e1
8:04:05 PM: deployId: 66a83bedf33962000821d7e3
8:04:05 PM:
8:04:05 PM: ❯ Current directory
8:04:05 PM: /opt/build/repo/src
8:04:05 PM:
8:04:05 PM: ❯ Config file
8:04:05 PM: No config file was defined: using default values.
8:04:05 PM:
8:04:05 PM: ❯ Context
8:04:05 PM: production
8:04:05 PM:
8:04:05 PM: Build command from Netlify app
8:04:05 PM:
8:04:05 PM: $ npm run build
8:04:05 PM: > aaa_realty@1.0.0 build
8:04:05 PM: > CI='' npx tailwindcss -i ./src/input.css -o ./src/output.css --minify
8:04:06 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
8:04:06 PM: sh: 1: tailwindcss: Permission denied
8:04:06 PM:
8:04:06 PM: "build.command" failed
8:04:06 PM: ────────────────────────────────────────────────────────────────
8:04:06 PM:
8:04:06 PM: Error message
8:04:06 PM: Command failed with exit code 126: npm run build (https://ntl.fyi/exit-code-126)
8:04:06 PM:
8:04:06 PM: Error location
8:04:06 PM: In Build command from Netlify app:
8:04:06 PM: npm run build
8:04:06 PM:
8:04:06 PM: Resolved config
8:04:06 PM: build:
8:04:06 PM: base: /opt/build/repo/src
8:04:06 PM: command: npm run build
8:04:06 PM: commandOrigin: ui
8:04:06 PM: publish: /opt/build/repo/src
8:04:06 PM: publishOrigin: ui
8:04:06 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
8:04:06 PM: Failing build: Failed to build site
8:04:07 PM: Finished processing build request in 11.708s
Here is my package.json:
"name": "aaa_realty",
"version": "1.0.0",
"description": "",
"main": "index.js",
"scripts": {
"build": "CI='' npx tailwindcss -i ./src/input.css -o ./src/output.css --minify",
"test": "echo \"Error: no test specified\" && exit 1"
"keywords": [],
"author": "",
"license": "ISC",
"devDependencies": {
"tailwindcss": "^3.4.6"
Here is my file structure:
