Hello, I am having some issues building my next.js application. It works fine locally, but when I go to build it on netlify I keep getting this error code. I have tried to modify the build settings on netlify to “CI= npm run build”
Also have tried to change the env variables to “CI= false” and still having issues.
This is my build log. Hope I can get some help with this! Thanks in advance
and this is my package.json
“name”: “nextjs-app”,
“version”: “0.1.0”,
“private”: true,
“scripts”: {
“dev”: “next dev”,
“build”: “next build”,
“start”: “next start”,
“lint”: “next lint”
“dependencies”: {
“@popperjs/core”: “^2.11.8”,
“bootstrap”: “^5.3.3”,
“next”: “^14.2.3”,
“popper.js”: “^1.16.1”,
“react”: “^18.3.1”,
“react-apexcharts”: “^1.4.1”,
“react-countup”: “^6.5.3”,
“react-dom”: “^18.3.1”,
“react-intersection-observer”: “^9.10.2”,
“react-timer-hook”: “^3.0.7”,
“react-use”: “^17.5.0”,
“sass”: “^1.77.2”,
“swiper”: “^11.1.3”
“devDependencies”: {
“@types/node”: “^20”,
“@types/react”: “^18”,
“@types/react-dom”: “^18”,
“eslint”: “^8”,
“eslint-config-next”: “14.2.3”,
“typescript”: “^5”
