We need to know your netlify site name. Example: gifted-antelope-58b104.netlify.app
DNS issues? Tell us the custom domain, tell us the error message! We can’t help if we don’t know your domain.
Build problems? Link or paste the FULL build log & build settings screenshot
Did you try Ask Netlify , our generative AI chatbot, before posting? It pulls info from Support Guides and recent solved forums posts.
Site name: statuesque-froyo-9b8827
https://statuesque-froyo-9b8827.netlify.app/
I tried to copy and paste the build log but I get an error stating that new users can only post 6 links.
clarnx
January 11, 2024, 10:06pm
2
Hi @lellis09 ,
You can copy a snippet of where the error is happening in your build logs here so that I can help with the debugging.
Thanks.
Hello new to using both Next.js and Netlify. I just started the build process an it failed.
Site name : soft-cucurucho-6512c4
Below is a image of my configuration settings
8:37:17 AM: Netlify Build
8:37:17 AM: ────────────────────────────────────────────────────────────────
8:37:17 AM:
8:37:17 AM: ❯ Version
8:37:17 AM: @netlify/build 29.32.0
8:37:17 AM:
8:37:17 AM: ❯ Flags
8:37:17 AM: baseRelDir: true
8:37:17 AM: buildId: 65a14e94c9a4b000a2702ccf
8:37:17 AM: deployId: 65a14e94c9a4b000a2702cd1
8:37:17 AM:
8:37:17 AM: ❯ Current directory
8:37:17 AM: /opt/build/repo
8:37:17 AM:
8:37:17 AM: ❯ Config file
8:37:17 AM: No config file was defined: using default values.
8:37:17 AM:
8:37:17 AM: ❯ Context
8:37:17 AM: production
8:37:17 AM:
8:37:17 AM: ❯ Installing plugins
8:37:17 AM: - @netlify/plugin-nextjs@4.41.3
8:37:28 AM: Failed during stage "building site": Build script returned non-zero exit code: 2
8:37:26 AM:
8:37:26 AM: ❯ Using Next.js Runtime - v4.41.3
8:37:27 AM:
8:37:27 AM: @netlify/plugin-nextjs (onPreBuild event)
8:37:27 AM: ────────────────────────────────────────────────────────────────
8:37:27 AM:
8:37:27 AM: No Next.js cache to restore.
8:37:27 AM: Netlify configuration property "build.environment.NEXT_PRIVATE_TARGET" value changed.
8:37:27 AM:
8:37:27 AM: (@netlify/plugin-nextjs onPreBuild completed in 51ms)
8:37:27 AM:
8:37:27 AM: Build command from Netlify app
8:37:27 AM:
8:37:27 AM: $ next build
8:37:27 AM: bash: next: command not found
8:37:27 AM:
8:37:27 AM: "build.command" failed
8:37:27 AM:
8:37:27 AM: Error message
8:37:27 AM: Command failed with exit code 127: next build (https://ntl.fyi/exit-code-127)
8:37:27 AM:
8:37:27 AM: Error location
8:37:27 AM: In Build command from Netlify app:
8:37:27 AM: next build
8:37:27 AM:
8:37:27 AM: Resolved config
8:37:27 AM: build:
8:37:27 AM: command: next build
8:37:27 AM: commandOrigin: ui
8:37:27 AM: environment:
8:37:27 AM: - NEXT_PRIVATE_TARGET
8:37:27 AM: publish: /opt/build/repo/.next.
8:37:27 AM: publishOrigin: ui
8:37:27 AM: plugins:
8:37:27 AM: - inputs: {}
8:37:27 AM: origin: ui
8:37:27 AM: package: "@netlify/plugin-nextjs"
8:37:28 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
8:37:28 AM: Failing build: Failed to build site
8:37:28 AM: Finished processing build request in 18.965s
please disregard this I actually just realised my github repo is empty but I will get in touch if I need help later. Thank you!
okay i am having issues using fs getting the following error mulitple times
Module not found: Can"t resolve “fs”
I saw this thread node.js - Module not found: Can't resolve 'fs' in Next.js application - Stack Overflow
seems like the same issue however I am not really sure where I need to add that next.config.js file
clarnx
January 12, 2024, 6:55pm
6
Hi @Kysetopher , the instructions in the Stack Overflow link states you should add a next.config.js in your project root if there is none.
After the content of the next.config.js should look like the code below.
module.exports = {
webpack5: true,
webpack: (config) => {
config.resolve.fallback = { fs: false };
return config;
Note that the above configuration is for Webpack 5
Thanks.
Hello clarence
thanks for your help. I found a solution to that problem but it seems I am still having general build issues. Im not sure whats causing the issue now but my research is telling me I may not have everything correct in my package.json file. Can i touch base with you later for help. I will be available around 6:30 PCT
clarnx
February 2, 2024, 7:21am
8
Hi @Kysetopher I want to find out if you have been able to resolve your problem.
Thanks.
