Triggering publish using build hooks
Hi,
My repos are in github and I want to deploy/publish using webhooks but as I’ve seen in this post https://answers.netlify.com/t/triggering-publish-with-a-webhook/4191/13 that it needs to be done from your side.
Could you please remove the webhooks from repos so I can deploy/publish using buildhooks api call.
my username is neoms21@gmail.com
Thanks
Hi,
Name of my sites are :
just-menu.netlify.app
restaurant-justmenu.netlify.app
Hey @neoms21,
We’ve disabled automatic builds on those sites, so you should be able to publish via hook. Please let us know if that’s not the case!
Hey Jen,
Thanks, it’s working on one of the repos. I shall test it on another one later today and post here.
Thanks a ton again.
M
