TLS handshake fails on one Netlify edge (99.83.190.102) causing intermittent ERR_SSL_PROTOCOL_ERROR
Hi Netlify team,
I’m experiencing intermittent ERR_SSL_PROTOCOL_ERROR on my custom domain:
The issue appears to affect only one Netlify edge.
DNS:
75.2.60.5
99.83.190.102
Testing each edge individually:
Working:
curl -Iv --resolve vaid.store:443:75.2.60.5 https://vaid.store
Result:
  • Valid Let’s Encrypt certificate
  • HTTP/2 200 OK
Failing:
curl -Iv --resolve vaid.store:443:99.83.190.102 https://vaid.store
Result:
LibreSSL: error:1404B438:SSL routines:ST_CONNECT:tlsv1 alert internal error
SSL Labs also reports:
  • 75.2.60.5 → A+
  • 99.83.190.102 → Failed to communicate with secure server
My DNS is configured correctly:
A 75.2.60.5
A 99.83.190.102
CNAME www → tanvishcouture.netlify.app
The domain is attached to Netlify and is marked as the primary domain.
Could someone please check the TLS/certificate configuration for the 99.83.190.102 edge or reprovision it?
Thank you.
