I migrated from Gatsby Cloud this month and everything was going well until today, when we started to have this error:
10:32:10 AM: Failed to create function on AWS Lambda: invalid parameter for lambda creation: Unzipped size must be smaller than 262144000 bytes
10:32:17 AM: The function "SSR-ENGINE" is larger than the 50MB limit. Please consider reducing it.
10:32:20 AM: The function "SSR-ENGINE" is larger than the 50MB limit. Please consider reducing it.
10:32:22 AM: The function "SSR-ENGINE" is larger than the 50MB limit. Please consider reducing it.
10:32:25 AM: The function "SSR-ENGINE" is larger than the 50MB limit. Please consider reducing it.
10:32:00 AM: Deploy site
10:32:00 AM:
@diego.valdez , @audrey curious to hear about what the problem was. We’re experience the exact same issue after migrating from Gatsby Cloud to Netlify.
Same problem. Need to migrate sites from Gatsby Cloud because it shuts down on October 31. But one site does not build on Netlify because of the error:
The function “__DSG” is larger than the 50MB limit. Please consider reducing it.
“defer” in gatsby-node.js is set to “false”.
We need at least a temporary solution to be able to go on.
Sadly, Netlify support says they will answer in 4 days. If that answer is not immediately a solution, then the site dies.
