Site is Netlify App
just trying to the a svelte-kit site up. npm run build complete successfully on local. The netlify build breaks on "Deploy directory ‘build’ does not exist. The build command is npm run build
. build directory is set to public
, I don’t know if that’s right. Any clues appreciated.
I’ve modified your repo to incorporate the required changes. Now, it should work without any additional config: https://github.com/Hrishikesh-K/svelte-kit-tailwind-spike
In short, you need to follow this: Introduction • Docs • SvelteKit and use the adapter-netlify
mentioned there.
Perfect, thanks. I know the general direction of the solution but was hung up on the config syntax. Now I’m up and running, much appreciated.
