Sudden failed build due to python dependency
Without any changes from our side, the build on our site “netdata” (https://docs.netdata.cloud) started failing. The error messages are below.
6:23:12 AM: Starting build script
6:23:12 AM: Installing dependencies
6:23:12 AM: /usr/local/bin/run-build-functions.sh: line 170: /opt/buildhome/python3.6/bin/activate: No such file or directory
6:23:12 AM: Shutting down logging, 5 messages pending
Our runtime.txt has 3.5, no idea why run-build-functions.sh is looking for python3.6, which is not supported (as per build-image/included_software.md at xenial · netlify/build-image · GitHub)
If the source repository or the build log are public, can you share links to them?
See under docs/generator for buildhtml.sh and the requirements.txt
Are you still running into this? That is really strange, since you’re right that we don’t support 3.6. It looks like your runtime.txt used to say 3.6, so I’m wondering if there was a cache issue at some point. I think our next suggestion would be to check your buildhtml.sh file and if that’s what pulls the Python version, locally print the Python version that it finds and confirm that it is 3.5. If it is, then my next suggestion would be to deploy with the “Clear cache and deploy site” button:
Do you want to give those a shot and let us know how they go?
I am experiencing the same issue here.
    2:12:03 AM: Preparing Git Reference refs/heads/master
    2:12:03 AM: Starting build script
    2:12:03 AM: Installing dependencies
    2:12:03 AM: /usr/local/bin/run-build-functions.sh: line 170: /opt/buildhome/pythonpython-3.6.9/bin/activate: No such file or directory
    2:12:03 AM: Error setting python version from runtime.txt
    2:12:03 AM: Please see https://github.com/netlify/build-image/#included-software for current versions
Am using vuepress for the docs and it has nothing do with the python part of the project.
Answered you over here :slight_smile: Manage builds on projects with multiple languages - #2 by jen
