Subject: Request: increase synchronous function timeout to 26 seconds (Pro plan)
Hi Netlify team,
I’m on the Pro plan and would like the synchronous function timeout raised to the maximum of 26 seconds for my site.
Site: klarphi-workspace (klarphi-workspace.netlify.app)
Site ID: 331b0a50-2572-4dd6-a161-6dd6c66ff7e5
The site is a Next.js app that proxies Anthropic Claude API calls to generate structured business analysis. Responses typically take 10-15 seconds and are currently returning 504 after the default 10-second limit.
I already have the following configured in netlify.toml:
functions
timeout = 26
As I understand it, this setting requires activation on your side for it to take effect. Could you please enable the 26-second timeout for this site?
Thank you.
i will get an admin to help
I can understand why you’re requesting this, especially if the function normally takes 10–15 seconds and is consistently hitting the 10-second limit. A 26-second timeout would give the API calls enough room to complete without unnecessary 504s. Hopefully the Netlify team can enable it for your site. Golf Gifts
