I’ve deployed my site successfully to Netlify using a private GitHub repo. The deploy is working perfectly at:
https://mayyal.netlify.app
However, I’m having trouble provisioning an SSL certificate for my custom domain:
- Custom Domain:
mayyalmayyal.com - Netlify Site Name:
mayyal - Status: Deploy works, but HTTPS is not active for the custom domain
- Attempts: This is my third time attempting to set this up. I’ve removed and re-added the domain multiple times.
What I’ve Done:
- DNS is managed through GoDaddy, not Netlify.
- I’ve added the correct DNS records (
Arecord and/orCNAME) and verified them via DNS lookup tools. - I’ve waited over 24 hours for propagation.
- I’m unable to switch to Netlify DNS because I have a live restaurant website running on a subdomain under the same root domain.
I’ve attached a screenshot of my DNS configuration in GoDaddy for your reference.
Can you please assist me in manually provisioning the SSL certificate or identifying what might be causing the delay/failure?
Thanks in advance,
