Howdy, I’m using Netlify DNS and the DNS configuration check passes, but I’m getting the message “We could not provision a Let’s Encrypt certificate for your custom domain.”
- Netlify site name: eloquent-benz-fbf789.netlify.app
Thanks!
Thanks!
Hi @blakehall
I just took a quick look at the cert appears to have been provisioned correctly at this point. We might have just needed to wait a little bit. Are you still seeing a problem on your end?
