Joker
June 13, 2023, 3:40pm
1
I am having difficulty to deploy my site through GitHub repo. I have tried every possible solution that others suggested, but didn’t get the result that I wanted. When I deployed it manually with drag and drop I got working site.
The site name for the working files is: [https://serene-praline-99ca0e.netlify.app/login ]
The site name for the non-working files that have been linked to my git repo of the same files is : [https://taupe-lokum.netlify.app/ ].
I tried to deploy another GitHub repo, but they all failed .
It would be great to be able to link GitHub so that I can have continuous deployment. Thank you for your help!
RK
clarnx
June 14, 2023, 10:40am
2
HI @Joker , welcome to the Netlify Support Forums.
If you have not already read the Support Guide below kindly do so regarding problems with deployment.
We want to help you build and deploy your site as easily as possible. Our team has written numerous support guides on frequently encountered problems during builds, build/deploy behaviour, drag and drop deploys, and more. In an effort to streamline your searching, we have compiled a list of our Support Guides related to builds and deploys. Each guide contains a ton of useful debugging tips that can likely help you solve your problem.
Troubleshooting and high-level debugging
Frequently encount…
Thanks.
