Search and translation of "min read" not working
https://davidecalabria.netlify.app/
Good evening,
I’m trying to make a blog with Astro + Tailwind Css and Tina CMS. I used this template GitHub - danielcgilibert/blog-template: 📚 Openblog is an elegant, simple, and user-friendly blog. Focused on accessibility, SEO and performance., and I traslated it in italian at this repository https://github.com/DavideCalabria/blog-template-it.
Then I deployed it to netlify, but the “reading time” of the posts is not translated in italian (locally it is translated well!!!).
In prodution it should work also the Search botton but it doesn’t.
Can you help me, please?
Hi, @DavideCalabria. It looks like this site was deleted.
Hi and give thanks for the answer. The blog now is at https://davcal.netlify.app/ (www.davidecalabria.com). I solved the Search buttom question by myself, but I couldn’t for the reading time.
The matter is that locally I have a folder called node_modules that I touched to traslate the reading time, but there isn’t the github repo.
Could you explain how this is a Netlify issue? Sounds like a code issue and you should try reaching out to the theme’s developer for that.
Sorry & Give thanks!
I thought someone could have had the same problem on this forum.
I’ll follow your suggestion.
