Same Source Code: Build failure on one site and not an another site
  • we need to know your netlify site name. Example: https://vantashala.netlify.app/
  • Build problems? Link or paste the FULL build log & build settings screenshot
    log: Netlify App
My source code repository is the same and it is building and deploying good on one site and not on another site.
Successful deployment: vsdevqa.netlify.app
Failing to build on: vantashala.netlify.app
Error log:
5:43:33 PM: 63 │ ‘sm’: $grid-gutter / 6npm ERR! code ELIFECYCLE
5:43:33 PM: npm ERR! errno 1
5:43:33 PM: npm ERR! vantashala@0.1.0 build: vue-cli-service build
5:43:33 PM: npm ERR! Exit status 1
5:43:33 PM: npm ERR! Failed at the vantashala@0.1.0 build script.
5:43:33 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
5:43:34 PM: npm ERR! A complete log of this run can be found in:
5:43:34 PM: npm ERR! /opt/buildhome/.npm/_logs/2022-08-23T22_42_47_547Z-debug.log
5:43:34 PM: ​
5:43:34 PM: ────────────────────────────────────────────────────────────────
5:43:34 PM: “build.command” failed
5:43:34 PM: ​
5:43:34 PM: Error message
5:43:34 PM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
5:43:34 PM: ​
5:43:34 PM: Error location
5:43:34 PM: In Build command from Netlify app:
5:43:34 PM: npm run build
Hi, @haigopi. The working build logs show this:
3:34:25 PM: Now using node v14.20.0 (npm v6.14.17)
The non-working build logs show this:
8:12:38 PM: Now using node v12.18.0 (npm v6.14.4)
So, the first thing I recommend is getting the non-working node version to make the working version. There are several ways to set the node version and there is more documentation here:
If changing the node version doesn’t resolve this or if there are other questions, please let us know.
Thank you! Updated the build version and I could able to see the same in logs
3:29:09 PM: Downloading and installing node v14.20.0…
The issue still persists. Netlify App
Something else might be going with the env! The other domain vsdevqa.netlify.app 's build is passing though.
@luke Any guidance will be appreciated. As the build issue still persists.
Thanks.
Hey @haigopi
Unfortunately the deploy log you shared is private. If you are able to make it public, or share the text here, the community at large could provide assistance.
Here is the log of the failing build. I also attached the log of the successful build of the same code on another site at the bottom.
12:07:30 AM: Build ready to start
12:07:30 AM: ---------------------------------------------------------------------
WARNING: Starter plan site builds from private, organization-owned GitHub repositories will fail after September 30, 2022.
This build was triggered from a private, organization-owned GitHub repository, which is now a feature of the Pro plan.
To avoid service disruption, please upgrade your plan or change your repository settings by September 30, 2022.
If you upgrade to Pro, you can get the first month free:
For more details, including how to continue building your site on the Starter plan, visit our FAQ page:
12:07:31 AM: build-image version: d7b3dbfb0846505993c9a131894d1858074c90b4 (focal)
12:07:31 AM: build-image tag: v4.10.1
12:07:31 AM: buildbot version: f45292fab0b32cea549baa8489f553abb9d888be
12:07:31 AM: Building without cache
12:07:31 AM: Starting to prepare the repo for build
12:07:32 AM: No cached dependencies found. Cloning fresh repo
12:07:32 AM: git clone github-com/VantaShala/ui
12:07:33 AM: Preparing Git Reference refs/heads/master
12:07:34 AM: Parsing package.json dependencies
12:07:35 AM: Starting build script
12:07:35 AM: Installing dependencies
12:07:35 AM: Python version set to 2.7
12:07:35 AM: Downloading and installing node v14.19.0…
12:07:35 AM: Downloading nodejs-org/dist/v14.19.0/node-v14.19.0-linux-x64.tar.xz…
12:07:36 AM: Computing checksum with sha256sum
12:07:36 AM: Checksums matched!
12:07:37 AM: Now using node v14.19.0 (npm v6.14.16)
12:07:38 AM: Started restoring cached build plugins
12:07:38 AM: Finished restoring cached build plugins
12:07:38 AM: Attempting ruby version 2.7.1, read from environment
12:07:38 AM: Required ruby-2.7.1 is not installed - installing.
12:07:38 AM: Searching for binary rubies, this might take some time.
12:07:39 AM: Found remote file rvm_io.global.ssl.fastly.net/binaries/ubuntu/20.04/x86_64/ruby-2.7.1.tar.bz2
12:07:39 AM: Checking requirements for ubuntu.
12:07:39 AM: Requirements installation successful.
12:07:39 AM: ruby-2.7.1 - #configure
12:07:39 AM: ruby-2.7.1 - #download
12:07:40 AM: ruby-2.7.1 - #validate archive
12:07:43 AM: ruby-2.7.1 - #extract
12:07:45 AM: ruby-2.7.1 - #validate binary
12:07:45 AM: ruby-2.7.1 - #setup
12:07:46 AM: ruby-2.7.1 - #gemset created /opt/buildhome/.rvm/gems/ruby-2.7.1 at global
12:07:46 AM: ruby-2.7.1 - #importing gemset /opt/buildhome/.rvm/gemsets/global.gems…
12:07:46 AM: ruby-2.7.1 - #generating global wrappers…
12:07:46 AM: ruby-2.7.1 - #importing gemsetfile /opt/buildhome/.rvm/gemsets/default.gems evaluated to empty gem list
12:07:47 AM: ruby-2.7.1 - #generating default wrappers…
12:07:47 AM: Using /opt/buildhome/.rvm/gems/ruby-2.7.1
12:07:47 AM: Using ruby version 2.7.1
12:07:47 AM: Using PHP version 8.0
12:07:47 AM: No npm workspaces detected
12:07:47 AM: Started restoring cached node modules
12:07:47 AM: Finished restoring cached node modules
12:07:47 AM: Installing NPM modules using NPM version 6.14.16
12:07:51 AM: npm WARN deprecated eslint-loader at 2.2.1: This loader has been deprecated. Please use eslint-webpack-plugin
12:07:51 AM: npm WARN deprecated axios at 0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see github-com/axios/axios/pull/3410
12:07:53 AM: npm WARN deprecated request at 2.88.2: request has been deprecated, see github-com/request/request/issues/3142
12:07:53 AM: npm WARN deprecated html-webpack-plugin at 3.2.0: 3.x is no longer supported
12:07:54 AM: npm WARN deprecated at types/googlemaps at 3.43.3: Types for the Google Maps browser API have moved to at types/google.maps. Note: these types are not for the googlemaps npm package, which is a Node API.
12:07:56 AM: npm WARN deprecated at hapi/joi at 15.1.1: Switch to ‘npm install joi’
12:07:56 AM: npm WARN deprecated request-promise at 4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see github-com/request/request/issues/3142
12:07:58 AM: npm WARN deprecated uuid at 3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See v8.dev/blog/math-random for details.
12:07:59 AM: npm WARN deprecated har-validator at 5.1.5: this library is no longer supported
12:07:59 AM: npm WARN deprecated puppeteer at 1.20.0: Version no longer supported. Upgrade to at latest
12:08:00 AM: npm WARN deprecated chokidar at 2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
12:08:00 AM: npm WARN deprecated core-js at 2.6.12: core-js at <3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
12:08:02 AM: npm WARN deprecated at hapi/hoek at 8.5.1: This version has been deprecated and is no longer supported or maintained
12:08:02 AM: npm WARN deprecated at hapi/bourne at 1.3.2: This version has been deprecated and is no longer supported or maintained
12:08:02 AM: npm WARN deprecated at hapi/address at 2.1.4: Moved to ‘npm install at sideway/address’
12:08:02 AM: npm WARN deprecated at hapi/topo at 3.1.6: This version has been deprecated and is no longer supported or maintained
12:08:02 AM: npm WARN deprecated debug at 3.2.6: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (github-com/visionmedia/debug/issues/797)
12:08:02 AM: npm WARN deprecated mkdirp at 0.5.4: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
12:08:03 AM: npm WARN deprecated request-promise-native at 1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see github-com/request/request/issues/3142
12:08:06 AM: npm WARN deprecated fsevents at 1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
12:08:06 AM: npm WARN deprecated querystring at 0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
12:08:07 AM: npm WARN deprecated source-map-resolve at 0.5.3: See github-com/lydell/source-map-resolve#deprecated
12:08:07 AM: npm WARN deprecated sane at 4.1.0: some dependency vulnerabilities fixed, support for node < 10 dropped, and newer ECMAScript syntax/features added
12:08:07 AM: npm WARN deprecated urix at 0.1.0: Please see github-com/lydell/urix#deprecated
12:08:08 AM: npm WARN deprecated svgo at 1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
12:08:09 AM: npm WARN deprecated source-map-url at 0.4.1: See github-com/lydell/source-map-url#deprecated
12:08:09 AM: npm WARN deprecated resolve-url at 0.2.1: github-com/lydell/resolve-url#deprecated
12:08:09 AM: npm WARN deprecated stable at 0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: developer.mozilla-org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/sort#browser_compatibility
12:08:10 AM: npm WARN deprecated left-pad at 1.3.0: use String.prototype.padStart()
12:08:52 AM: > deasync at 0.1.28 install /opt/build/repo/node_modules/deasync
12:08:52 AM: > node ./build.js
12:08:52 AM: linux-x64-node-14 exists; testing
12:08:52 AM: Binary is fine; exiting
12:08:53 AM: > puppeteer at 1.20.0 install /opt/build/repo/node_modules/puppeteer
12:08:53 AM: > node install.js
12:08:56 AM: Chromium downloaded to /opt/build/repo/node_modules/puppeteer/.local-chromium/linux-686378
12:08:56 AM: > yorkie at 2.0.0 install /opt/build/repo/node_modules/yorkie
12:08:56 AM: > node bin/install.js
12:08:56 AM: CI detected, skipping Git hooks installation
12:08:56 AM: > chromedriver at 81.0.0 install /opt/build/repo/node_modules/chromedriver
12:08:56 AM: > node install.js
12:08:57 AM: Current existing ChromeDriver binary is unavailable, proceeding with download and extraction.
12:08:57 AM: Downloading from file: chromedriver.storage.googleapis-com/81.0.4044.69/chromedriver_linux64.zip
12:08:57 AM: Saving to file: /opt/buildhome/tmp/81.0.4044.69/chromedriver/chromedriver_linux64.zip
12:08:57 AM: Received 1040K…
12:08:57 AM: Received 2080K…
12:08:57 AM: Received 3120K…
12:08:57 AM: Received 4160K…
12:08:57 AM: Received 4840K total.
12:08:57 AM: Extracting zip contents.
12:08:57 AM: Copying to target path /opt/build/repo/node_modules/chromedriver/lib/chromedriver
12:08:57 AM: Fixing file permissions.
12:08:57 AM: Done. ChromeDriver binary available at /opt/build/repo/node_modules/chromedriver/lib/chromedriver/chromedriver
12:08:57 AM: > node-sass at 5.0.0 install /opt/build/repo/node_modules/node-sass
12:08:57 AM: > node scripts/install.js
12:08:57 AM: Downloading binary from github-com/sass/node-sass/releases/download/v5.0.0/linux-x64-83_binding.node
12:08:58 AM: Download complete
12:08:58 AM: Binary saved to /opt/build/repo/node_modules/node-sass/vendor/linux-x64-83/binding.node
12:08:58 AM: Caching binary to /opt/buildhome/.npm/node-sass/5.0.0/linux-x64-83_binding.node
12:08:58 AM: > core-js at 2.6.12 postinstall /opt/build/repo/node_modules/babel-runtime/node_modules/core-js
12:08:58 AM: > node -e “try{require(‘./postinstall’)}catch(e){}”
12:08:58 AM: > core-js at 3.25.0 postinstall /opt/build/repo/node_modules/core-js
12:08:58 AM: > ejs at 2.7.4 postinstall /opt/build/repo/node_modules/webpack-bundle-analyzer/node_modules/ejs
12:08:58 AM: > node ./postinstall.js
12:08:58 AM: > cypress at 9.7.0 postinstall /opt/build/repo/node_modules/cypress
12:08:58 AM: > node index.js --exec install
12:08:59 AM: Note: Overriding Cypress cache directory to: ./node_modules/.cache/CypressBinary
12:08:59 AM: Previous installs of Cypress may not be found.
12:08:59 AM: Installing Cypress (version: 9.7.0)
12:08:59 AM: [STARTED] Task without title.
12:09:00 AM: [SUCCESS] Task without title.
12:09:00 AM: [STARTED] Task without title.
12:09:06 AM: [SUCCESS] Task without title.
12:09:06 AM: [STARTED] Task without title.
12:09:07 AM: You can now open Cypress by running: node_modules/.bin/cypress open
12:09:07 AM: on.cypress-io/installing-cypress
12:09:07 AM: > geckodriver at 1.22.3 postinstall /opt/build/repo/node_modules/geckodriver
12:09:07 AM: > node index.js
12:09:07 AM: Downloading geckodriver… Extracting… Complete.
12:09:07 AM: > node-sass at 5.0.0 postinstall /opt/build/repo/node_modules/node-sass
12:09:07 AM: > node scripts/build.js
12:09:07 AM: Binary found at /opt/build/repo/node_modules/node-sass/vendor/linux-x64-83/binding.node
12:09:07 AM: Testing binary
12:09:07 AM: Binary is fine
12:09:07 AM: > vuex-module-decorators at 1.2.0 postinstall /opt/build/repo/node_modules/vuex-module-decorators
12:09:07 AM: > node -e “try{require(‘./postinstall’)}catch(e){}”
12:09:09 AM: npm notice created a lockfile as package-lock.json. You should commit this file.
12:09:09 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents at ~2.3.2 (node_modules/chokidar/node_modules/fsevents):
12:09:09 AM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents at 2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
12:09:09 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents at ^1.2.7 (node_modules/watchpack-chokidar2/node_modules/chokidar/node_modules/fsevents):
12:09:09 AM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents at 1.2.13: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
12:09:09 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents at ^1.2.7 (node_modules/jest-haste-map/node_modules/fsevents):
12:09:09 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents at ^1.2.7 (node_modules/webpack-dev-server/node_modules/chokidar/node_modules/fsevents):
12:09:09 AM: added 2376 packages from 1554 contributors and audited 2383 packages in 81.387s
12:09:10 AM: 133 packages are looking for funding
12:09:10 AM: run npm fund for details
12:09:10 AM: found 39 vulnerabilities (2 low, 13 moderate, 23 high, 1 critical)
12:09:10 AM: run npm audit fix to fix them, or npm audit for details
12:09:10 AM: NPM modules installed
12:09:10 AM: Started restoring cached go cache
12:09:10 AM: Finished restoring cached go cache
12:09:10 AM: Installing Go version 1.14.4 (requested 1.14.4)
12:09:14 AM: unset GOOS;
12:09:14 AM: unset GOARCH;
12:09:14 AM: export GOROOT=‘/opt/buildhome/.gimme/versions/go1.14.4.linux.amd64’;
12:09:14 AM: export PATH="/opt/buildhome/.gimme/versions/go1.14.4.linux.amd64/bin:{PATH}"; 12:09:14 AM: go version >&2; 12:09:14 AM: export GIMME_ENV="/opt/buildhome/.gimme/env/go1.14.4.linux.amd64.env" 12:09:14 AM: go version go1.14.4 linux/amd64 12:09:14 AM: Installing missing commands 12:09:14 AM: Verify run directory 12:09:15 AM: ​ 12:09:15 AM: ──────────────────────────────────────────────────────────────── 12:09:15 AM: Netlify Build 12:09:15 AM: ──────────────────────────────────────────────────────────────── 12:09:15 AM: ​ 12:09:15 AM: ❯ Version 12:09:15 AM: at netlify/build 27.15.7 12:09:15 AM: ​ 12:09:15 AM: ❯ Flags 12:09:15 AM: baseRelDir: true 12:09:15 AM: buildId: 630af812fe01ec01eb7ac8f2 12:09:15 AM: deployId: 630af812fe01ec01eb7ac8f4 12:09:15 AM: ​ 12:09:15 AM: ❯ Current directory 12:09:15 AM: /opt/build/repo 12:09:15 AM: ​ 12:09:15 AM: ❯ Config file 12:09:15 AM: No config file was defined: using default values. 12:09:15 AM: ​ 12:09:15 AM: ❯ Context 12:09:15 AM: production 12:09:15 AM: ​ 12:09:15 AM: ──────────────────────────────────────────────────────────────── 12:09:15 AM: 1. Build command from Netlify app 12:09:15 AM: ──────────────────────────────────────────────────────────────── 12:09:15 AM: ​ 12:09:15 AM: npm run build
12:09:15 AM: > vantashala at 0.1.0 build /opt/build/repo
12:09:15 AM: > vue-cli-service build
12:09:16 AM: - Building for production…
12:09:16 AM: Starting type checking service…
12:09:16 AM: Using 1 worker with 2048MB memory limit
12:09:32 AM: [BABEL] Note: The code generator has deoptimised the styling of /opt/build/repo/node_modules/vuetify/dist/vuetify.js as it exceeds the max of 500KB.
12:09:37 AM: DEPRECATION WARNING: Using / for division outside of calc() is deprecated and will be removed in Dart Sass 2.0.0.
12:09:37 AM: Recommendation: math.div($border-radius-root, 2) or calc($border-radius-root / 2)
12:09:37 AM: More info and automated migrator: sass-lang-com/d/slash-div
12:09:37 AM: ╷
12:09:37 AM: 14 │ ‘sm’: $border-radius-root / 2,
12:09:37 AM: │ ^^^^^^^^^^^^^^^^^^^^^^^
12:09:37 AM: ╵
12:09:37 AM: node_modules/vuetify/src/styles/settings/_variables.scss 14:11 at import
12:09:37 AM: node_modules/vuetify/src/styles/settings/_index.sass 1:9 at import
12:09:37 AM: node_modules/vuetify/src/styles/styles.sass 2:9 at import
12:09:37 AM: stdin 2:9 root stylesheet
12:09:37 AM: ╷
12:09:37 AM: ╵
12:09:37 AM: Recommendation: math.div($grid-gutter, 2) or calc($grid-gutter / 2)
12:09:37 AM: ╷
12:09:37 AM: 57 │ $container-padding-x: $grid-gutter / 2 !default;
12:09:37 AM: ╵
12:09:37 AM: node_modules/vuetify/src/styles/settings/_variables.scss 57:23 at import
12:11:47 AM: DEPRECATION WARNING: Using / for division outside of calc() is deprecated and will be removed in Dart Sass 2.0.0.
12:11:47 AM: Recommendation: math.div($grid-gutter, 3) or calc($grid-gutter / 3)
12:11:47 AM: More info and automated migrator: sass-lang-com/d/slash-div
12:11:47 AM: ╷
12:11:47 AM: 64 │ ‘md’: $grid-gutter / 3,
12:11:48 AM: │ ^^^^^^^^^^^^^^^^
12:11:48 AM: ╵
12:11:48 AM: node_modules/vuetify/src/styles/settings/_variables.scss 64:11 at import
12:11:48 AM: node_modules/vuetify/src/styles/settings/_index.sass 1:9 at import
12:11:48 AM: node_modules/vuetify/src/styles/styles.sass 2:9 at import
12:11:48 AM: stdin 2:9 root stylesheet
12:11:48 AM: WARNING: 1 repetitive deprecation warnings omitted.
12:11:48 AM: DEPRECATION WARNING: Using / for division outside of calc() is deprecated and will be removed in Dart Sass 2.0.0.
12:11:48 AM: Recommendation: math.div($border-radius-root, 2) or calc($border-radius-root / 2)
12:11:48 AM: More info and automated migrator: sass-lang-com/d/slash-div
12:11:48 AM: ╷
12:11:48 AM: 14 │ ‘sm’: $border-radius-root / 2,
12:11:48 AM: │ ^^^^^^^^^^^^^^^^^^^^^^^
12:11:48 AM: ╵
12:11:48 AM: node_modules/vuetify/src/styles/settings/_variables.scss 14:11 at import
12:11:48 AM: Recommendation: math.div($grid-gutter, 2) or calc($grid-gutter / 2)
12:11:48 AM: ╷
12:11:48 AM: 57 │ $container-padding-x: $grid-gutter / 2 !default;
12:11:48 AM: ╵
12:11:49 AM: node_modules/vuetify/src/styles/settings/_variables.scss 57:23 at import
12:11:49 AM: node_modules/vuetify/src/styles/settings/_index.sass 1:9 at import
12:11:49 AM: node_modules/vuetify/src/styles/styles.sass 2:9 at import
12:11:49 AM: stdin 2:9 root stylesheet
12:11:49 AM: DEPRECATION WARNING: Using / for division outside of calc() is deprecated and will be removed in Dart Sass 2.0.0.
12:11:49 AM: Recommendation: math.div($grid-gutter, 12) npm ERR! code ELIFECYCLE
12:11:49 AM: npm ERR! errno 1
12:11:49 AM: npm ERR! vantashala at 0.1.0 build: vue-cli-service build
12:11:49 AM: npm ERR! Exit status 1
12:11:49 AM: npm ERR! Failed at the vantashala at 0.1.0 build script.
12:11:49 AM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
12:11:49 AM: npm ERR! A complete log of this run can be found in:
12:11:49 AM: npm ERR! /opt/buildhome/.npm/_logs/2022-08-28T05_11_08_745Z-debug.log
12:11:49 AM: ​
12:11:49 AM: ────────────────────────────────────────────────────────────────
12:11:49 AM: “build-command” failed
12:11:49 AM: ​
12:11:49 AM: Error message
12:11:49 AM: Command failed with exit code 1: npm run build (ntl.fyi/exit-code-1)
12:11:49 AM: ​
12:11:49 AM: Error location
12:11:49 AM: In Build command from Netlify app:
12:11:49 AM: npm run build
12:11:49 AM: ​
12:11:50 AM: Resolved config
12:11:50 AM: build:
12:11:50 AM: command: npm run build
12:11:50 AM: commandOrigin: ui
12:11:50 AM: environment:
12:11:50 AM: - NODE_VERSION
12:11:50 AM: publish: /opt/build/repo/dist
12:11:50 AM: publishOrigin: ui
12:11:50 AM: Caching artifacts
12:11:50 AM: Started saving node modules
12:11:50 AM: Finished saving node modules
12:11:50 AM: Started saving build plugins
12:11:50 AM: Finished saving build plugins
12:11:50 AM: Started saving pip cache
12:11:50 AM: Finished saving pip cache
12:11:50 AM: Started saving emacs cask dependencies
12:11:50 AM: Finished saving emacs cask dependencies
12:11:50 AM: Started saving maven dependencies
12:11:50 AM: Finished saving maven dependencies
12:11:50 AM: Started saving boot dependencies
12:11:50 AM: Finished saving boot dependencies
12:11:50 AM: Started saving rust rustup cache
12:11:50 AM: Finished saving rust rustup cache
12:11:50 AM: Started saving go dependencies
12:11:50 AM: Finished saving go dependencies
12:11:50 AM: Cached ruby version 2.7.1
12:11:51 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
12:11:51 AM: Failing build: Failed to build site
12:11:51 AM: Finished processing build request in 4m19.716624352s
Blockquote
Success build log:
3:21:00 PM: Build ready to start
3:21:01 PM: build-image version: d7b3dbfb0846505993c9a131894d1858074c90b4 (focal)
3:21:01 PM: build-image tag: v4.10.1
3:21:01 PM: buildbot version: f7070267d9348624fde5c2d682aa32cc686742a6
3:21:01 PM: Fetching cached dependencies
3:21:01 PM: Starting to download cache of 631.4MB
3:21:07 PM: Finished downloading cache in 6.148548321s
3:21:07 PM: Starting to extract cache
3:21:13 PM: Finished extracting cache in 5.913167427s
3:21:13 PM: Finished fetching cache in 12.155881113s
3:21:13 PM: Starting to prepare the repo for build
3:21:14 PM: Preparing Git Reference refs/heads/devqa
3:21:15 PM: Parsing package.json dependencies
3:21:16 PM: Starting build script
3:21:16 PM: Installing dependencies
3:21:16 PM: Python version set to 2.7
3:21:16 PM: Started restoring cached node version
3:21:17 PM: Finished restoring cached node version
3:21:18 PM: v14.20.0 is already installed.
3:21:18 PM: Now using node v14.20.0 (npm v6.14.17)
3:21:18 PM: Started restoring cached build plugins
3:21:18 PM: Finished restoring cached build plugins
3:21:18 PM: Attempting ruby version 2.7.2, read from environment
3:21:18 PM: Using ruby version 2.7.2
3:21:19 PM: Using PHP version 8.0
3:21:19 PM: No npm workspaces detected
3:21:19 PM: Started restoring cached node modules
3:21:19 PM: Finished restoring cached node modules
3:21:19 PM: Started restoring cached go cache
3:21:19 PM: Finished restoring cached go cache
3:21:19 PM: Installing Go version 1.16.5 (requested 1.16.5)
3:21:23 PM: unset GOOS;
3:21:23 PM: unset GOARCH;
3:21:23 PM: export GOROOT=‘/opt/buildhome/.gimme/versions/go1.16.5.linux.amd64’;
3:21:23 PM: export PATH="/opt/buildhome/.gimme/versions/go1.16.5.linux.amd64/bin:{PATH}"; 3:21:23 PM: go version >&2; 3:21:23 PM: export GIMME_ENV="/opt/buildhome/.gimme/env/go1.16.5.linux.amd64.env" 3:21:23 PM: go version go1.16.5 linux/amd64 3:21:23 PM: Installing missing commands 3:21:23 PM: Verify run directory 3:21:24 PM: ​ 3:21:24 PM: ──────────────────────────────────────────────────────────────── 3:21:24 PM: Netlify Build 3:21:24 PM: ──────────────────────────────────────────────────────────────── 3:21:24 PM: ​ 3:21:24 PM: ❯ Version 3:21:24 PM: at netlify/build 27.15.7 3:21:24 PM: ​ 3:21:24 PM: ❯ Flags 3:21:24 PM: baseRelDir: true 3:21:24 PM: buildId: 6306882b7880df0008949544 3:21:24 PM: deployId: 6306882b7880df0008949546 3:21:24 PM: ​ 3:21:24 PM: ❯ Current directory 3:21:24 PM: /opt/build/repo 3:21:24 PM: ​ 3:21:24 PM: ❯ Config file 3:21:24 PM: No config file was defined: using default values. 3:21:24 PM: ​ 3:21:24 PM: ❯ Context 3:21:24 PM: production 3:21:24 PM: ​ 3:21:24 PM: ──────────────────────────────────────────────────────────────── 3:21:24 PM: 1. Build command from Netlify app 3:21:24 PM: ──────────────────────────────────────────────────────────────── 3:21:24 PM: ​ 3:21:24 PM: npm run devbuild
3:21:24 PM: > vantashala at 0.1.0 devbuild /opt/build/repo
3:21:24 PM: > vue-cli-service build --mode devqa
3:21:25 PM: - Building for devqa…
3:21:26 PM: Starting type checking service…
3:21:26 PM: Using 1 worker with 2048MB memory limit
3:21:35 PM: [BABEL] Note: The code generator has deoptimised the styling of /opt/build/repo/node_modules/vuetify/dist/vuetify.js as it exceeds the max of 500KB.
3:21:52 PM: DEPRECATION WARNING: Using / for division outside of calc() is deprecated and will be removed in Dart Sass 2.0.0.
3:21:52 PM: Recommendation: math.div($border-radius-root, 2) or calc($border-radius-root / 2)
3:21:52 PM: More info and automated migrator: sass-lang-com/d/slash-div
3:21:52 PM: ╷
3:21:52 PM: 14 │ ‘sm’: $border-radius-root / 2,
3:21:52 PM: │ ^^^^^^^^^^^^^^^^^^^^^^^
3:21:52 PM: ╵
3:21:52 PM: node_modules/vuetify/src/styles/settings/_variables.scss 14:11 at import
3:21:52 PM: node_modules/vuetify/src/styles/settings/_index.sass 1:9 at import
3:21:52 PM: node_modules/vuetify/src/styles/styles.sass 2:9 at import
3:21:52 PM: stdin 2:9
3:26:21 PM: Recommendation: math.div($grid-gutter, 3) or calc($grid-gutter / 3)
3:26:21 PM: More info and automated migrator: sass-lang-com/d/slash-div
3:26:21 PM: ╷
3:26:21 PM: 64 │ ‘md’: $grid-gutter / 3,
3:26:21 PM: │ ^^^^^^^^^^^^^^^^
3:26:21 PM: ╵
3:26:21 PM: node_modules/vuetify/src/styles/settings/_variables.scss 64:11 at import
3:26:21 PM: node_modules/vuetify/src/styles/settings/_index.sass 1:9 at import
3:26:21 PM: node_modules/vuetify/src/styles/styles.sass 2:9 at import
3:26:21 PM: stdin 2:9 root stylesheet
3:26:21 PM: DEPRECATION WARNING: Using / for division outside of calc() is deprecated and will be removed in Dart Sass 2.0.0.
3:26:22 PM: Recommendation: math.div($grid-gutter, 3) or calc($grid-gutter / 3)
3:26:22 PM: More info and automated migrator: sass-lang-com/d/slash-div
3:26:22 PM: ╷
3:26:22 PM: 64 │ ‘md’: $grid-gutter / 3,
3:26:22 PM: │ ^^^^^^^^^^^^^^^^
3:26:22 PM: ╵
3:26:22 PM: node_modules/vuetify/src/styles/settings/_variables.scss 64:11 at import
3:26:22 PM: node_modules/vuetify/src/styles/settings/_index.sass 1:9 at import
3:26:22 PM: node_modules/vuetify/src/styles/styles.sass 2:9 at import
3:26:22 PM: stdin 2:9 root stylesheet
3:26:22 PM: WARNING: 1 repetitive deprecation warnings omitted.
3:26:22 PM: WARNING: 4 repetitive deprecation warnings omitted.
3:26:22 PM: WARNING: 3 repetitive deprecation warnings omitted.
3:26:22 PM: WARNING: 2 repetitive deprecation warnings omitted.
3:26:22 PM: ​
3:26:23 PM: (build-command completed in 3m 59.4s)
3:26:23 PM: ​
3:26:23 PM: ────────────────────────────────────────────────────────────────
3:26:23 PM: 2. Deploy site
3:26:23 PM: ​
3:26:23 PM: Site deploy was successfully initiated
3:26:23 PM: ​
3:26:23 PM: (Deploy site completed in 1.3s)
3:26:23 PM: ​
3:26:23 PM: Netlify Build Complete
3:26:23 PM: ​
3:26:23 PM: (Netlify Build completed in 4m 0.8s)
3:26:23 PM: Caching artifacts
3:26:23 PM: Started saving node modules
3:26:23 PM: Finished saving node modules
3:26:23 PM: Started saving build plugins
3:26:23 PM: Finished saving build plugins
3:26:23 PM: Started saving pip cache
3:26:23 PM: Finished saving pip cache
3:26:23 PM: Started saving emacs cask dependencies
3:26:23 PM: Finished saving emacs cask dependencies
3:26:23 PM: Started saving maven dependencies
3:26:24 PM: Finished saving maven dependencies
3:26:24 PM: Started saving boot dependencies
3:26:24 PM: Finished saving boot dependencies
3:26:24 PM: Started saving rust rustup cache
3:26:24 PM: Finished saving rust rustup cache
3:26:24 PM: Started saving go dependencies
3:26:24 PM: Finished saving go dependencies
3:26:24 PM: Build script success
3:26:43 PM: Uploading Cache of size 632.6MB
3:26:48 PM: Finished processing build request in 5m46.784691022s
Hey @haigopi
There is a different NodeJS version used on the failing
and the successful
Perhaps more importantly, is the build command.
On the failing I see
vs the successful
In the successful one, you are specifying a specific mode, a development mode I presume. In the failing one, no mode is specified, but possibly it is using production, this the deprecation warnings are causing the build to fail.
First, Thank you for your time to look into this.
  1. You are right, mode “devqa” supplies the environment-specific URLs that this app is required to connect. The default is production.
  2. I just tried if the version is the problem. But I tried both node versions and both of them failed.
  3. “the deprecation warnings” → This is a VUE JS + Vuetify App version 2.0+. Both sites have these warnings while one is successful and the other is not. Also, these warnings never caused the builds to fail in the last two years. I am guessing something somewhere is wrong after the ubuntu version update. Builds are failing after this environment upgrade I believe. I may be wrong as I updated the same for the other site as well. My local build is successful with the same node version.
I just cleared the cache and re-ran the build for the site which used to be Successful. Now, I see that build is failing as well. So, it might be some npm package causing the error, which is hard to figure out for me.
I was going to make that suggesting. Looking at the build logs, vuetify is a possibility
or sass
see: sass-lang-com/d/slash-div
If the build it working locally, you might want to pin the version of sass, or whatever package (possibly vuetify) that uses it.
