Run python script on public directory - post Hugo build
Hi all,
I have a Hugo website for myself which works perfectly fine.
I have been wondering if it is possible to run a python script on the public directory to conditionally inject some script and modify the HTML.
On local, I run the python script after the Hugo build and get the results.
Questions:
  1. How would I run this python script after Hugo build?
I haven’t tried this, but you can probably use build plugins: Create Build Plugins | Netlify Docs. Not sure if it supports Python, but since it’s installed on Netlify, maybe it would work.
