Hi Team,
I am facing issue with the pdf to download. After deployment i am facing issue to download the pdf.
Website: https://portfolio-sanjanatu.netlify.app/
github:GitHub - SanjanaTU/Sanjana_Portfolio
Hi Team,
Deployment status
4:38:25 PM: Netlify Build
4:38:25 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
4:38:25 PM: β
4:38:25 PM: β― Version
4:38:25 PM: @netlify/build 29.31.4
4:38:25 PM: β
4:38:25 PM: β― Flags
4:38:25 PM: baseRelDir: true
4:38:25 PM: buildId: 659eb9bdc52a3b088713b3a9
4:38:25 PM: deployId: 659eb9bdc52a3b088713b3ab
4:38:25 PM: β
4:38:25 PM: β― Current directory
4:38:25 PM: /opt/build/repo
4:38:25 PM: β
4:38:25 PM: β― Config file
4:38:25 PM: No config file was defined: using default values.
4:38:25 PM: β
4:38:25 PM: β― Context
4:38:25 PM: production
4:38:25 PM: β
4:38:25 PM: Build command from Netlify app
4:38:25 PM: β
4:38:25 PM: $ npm run build
4:38:25 PM: > portfolio-sanjanatu@0.0.0 build
4:38:25 PM: > vite build && cp src/assets/*.pdf dist/assets/
vite v5.0.11 building for productionβ¦
4:38:25 PM: transformingβ¦
4:38:29 PM: node_modules/three-stdlib/libs/lottie.js (13062:32) Use of eval in βnode_modules/three-stdlib/libs/lottie.jsβ is strongly discouraged as it poses security risks and may cause issues with minification.
4:38:31 PM: β 975 modules transformed.
4:38:31 PM: rendering chunksβ¦
4:38:31 PM: computing gzip sizeβ¦
4:38:31 PM: dist/index.html 0.49 kB β gzip: 0.32 kB
4:38:31 PM: dist/assets/reactjs-C2MbG7jx.png 4.10 kB
4:38:31 PM: dist/assets/figma-Ffo7LGA_.png 4.75 kB
4:38:31 PM: dist/assets/tesla-3qgPA5wV.png 4.95 kB
4:38:31 PM: dist/assets/tailwind-i0ent8iN.png 5.24 kB
4:38:31 PM: dist/assets/html-ZYS0Rs2I.png 5.32 kB
4:38:31 PM: dist/assets/css-5WRNGH9I.png 5.48 kB
4:38:31 PM: dist/assets/docker-60Ckme38.png 5.49 kB
4:38:31 PM: dist/assets/nodejs-XLcSyKqV.png 6.60 kB
4:38:31 PM: dist/assets/meta-wwPXefW1.png 7.75 kB
4:38:31 PM: dist/assets/redux-YIgjsQRx.png 7.77 kB
4:38:31 PM: dist/assets/shopify-fb2A323g.png 8.00 kB
4:38:31 PM: dist/assets/mongodb-51PRC_bF.png 8.05 kB
4:38:31 PM: dist/assets/logo-rK6fOP-X.svg 9.70 kB β gzip: 1.49 kB
4:38:31 PM: dist/assets/github-VH8e7qgP.png 11.07 kB
4:38:31 PM: dist/assets/starbucks-6YhUdmyp.png 16.75 kB
4:38:31 PM: dist/assets/creator-d3V1jrfE.png 21.77 kB
4:38:31 PM: dist/assets/mobile-zsmMcWH-.png 22.66 kB
4:38:31 PM: dist/assets/backend-IU17xwLW.png 28.78 kB
4:38:31 PM: dist/assets/logo_TU-tCiuNbwn.png 46.65 kB
4:38:31 PM: dist/assets/web-NPJKP6jW.png 59.04 kB
4:38:31 PM: dist/assets/Sanjana_FullStack_Resume-wWsbjXDq.pdf 82.84 kB
4:38:31 PM: dist/assets/jobit-ZLvUsGJU.png 755.05 kB
4:38:31 PM: dist/assets/carrent-XLSc4ln5.png 758.93 kB
4:38:31 PM: dist/assets/TravelTales-X6_gJl6i.png 1,933.31 kB
4:38:31 PM: dist/assets/MyPlaceKeeper-RxSmlDSR.png 2,168.22 kB
4:38:31 PM: dist/assets/tripguide-4V5ZJwxS.png 3,417.51 kB
4:38:31 PM: dist/assets/index-2SeK4YRp.css 22.63 kB β gzip: 5.10 kB
4:38:31 PM: dist/assets/index-aBJ6mBcC.js 1,207.86 kB β gzip: 352.76 kB
4:38:31 PM:
4:38:31 PM: (!) Some chunks are larger than 500 kB after minification. Consider:
4:38:31 PM: - Using dynamic import() to code-split the application
4:38:31 PM: - Use build.rollupOptions.output.manualChunks to improve chunking: Configuration Options | Rollup
4:38:31 PM: - Adjust chunk size limit for this warning via build.chunkSizeWarningLimit.
4:38:31 PM: β built in 6.16s
4:38:31 PM: β
4:38:31 PM: (build.command completed in 6.6s)
4:38:31 PM: β
4:38:32 PM: (Netlify Build completed in 6.8s)
4:38:51 PM: Section completed: building
4:38:53 PM: Finished processing build request in 42.125s
Complete
4:38:31 PM: Deploy site
4:38:31 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
4:38:31 PM: β
4:38:31 PM: Starting to deploy site from βdistβ
4:38:31 PM: Calculating files to upload
4:38:32 PM: 0 new files to upload
4:38:32 PM: 0 new functions to upload
4:38:32 PM: Section completed: deploying
4:38:32 PM: Site deploy was successfully initiated
4:38:32 PM: β
4:38:32 PM: (Deploy site completed in 126ms)
Complete
Complete
dist/
29 files
54 files
5 files
Hi @Sanjana,
Thanks for reaching out and welcome to Netlifyβs Support Forums!
Could you clarify the issue youβre having with downloading the pdf? Could you provide steps to replicate the issue? Are you seeing an error message in the dev console?
@Sanjana The issue is that the URL is wrong.
Your Resume link is pointing to:
This is trying to load:
https://portfolio-sanjanatu.netlify.app/src/assets/Sanjana_FullStack_Resume.pdf
The only PDF mentioned in your build log is:
You also have a post vite build command of cp src/assets/*.pdf dist/assets/
Which is attempting to copy any pdf files from src/assets/ to dist/assets/
Assuming that you have set your Publish directory to dist and that the original filename was Sanjana_FullStack_Resume.pdf that means the fileβs locations are:
The one output by vite β
https://portfolio-sanjanatu.netlify.app/assets/Sanjana_FullStack_Resume-wWsbjXDq.pdf
The one you moved over via the cp command β
https://portfolio-sanjanatu.netlify.app/assets/Sanjana_FullStack_Resume.pdf
Both of those exist.
Thank you @nathanmartin
I was able to fix the issue with your guidance. ![]()
I too have a question
During my bootcamp my instructor asked us not to use anchor tag as it could create some issue during the deployment in netlify.
Does really the netlify create a problem if we use tag in our project during deployment?
@Sanjana What do you mean by an βanchor tagβ?
You can write what you mean in a Markdown βcode blockβ on this forum by using three backticks ``` before and after the code, e.g.
<a href="#myitem">This is some HTML code</a>
Do you mean the βanchor elementβ itself?
https://developer.mozilla.org/en-US/docs/Web/HTML/Element/a
Or specifically what many people refer to as an βanchor linkβ where the href is set to an identifier on the page, e.g. #myitem?
