Problem with: 'Reading and parsing configuration files'
Hello dear support command, I’m really sorry that I’ve made this issue, because in there are the same 2 topics. But I cannot deploy my site after introducing webpack in my app.
I’ve read the 2 topics, but It doesn’t work for me, please, help me.
Site name: earnenglishwords.netlify.app
The build log:
The problem happens on first line, where I use “import ‘./style.css’”
Could you help please?
P.S. I can’t put in here my another images because I’m new user in here, but, I think it will help. So ask me for more details there Sr233@yandex.ru
Thank you for your time.
I deployed your site using Netlify Drop. This appears in the console.
Uncaught SyntaxError: Cannot use import statement outside a module
because you have import "./style.css" in your index.js. Remove the import and add <link rel="stylesheet" type="text/css" href="style.css"/> to into the <head> ... </head> of your index.html.
Also, consider making your video smaller, converting it to webm, or using a service such as Cloudinary to host the video or use Netlify LFS.
I’ve changed as you said, but it still doesn’t work.
I’ve tried to fix that within redeploying, but it didn’t help too.
And yes, I used Netlify Drop, it works there. So a problem might be in Netlify?
I have deployed your site at https://stoic-panini-2296fb.netlify.app using drag and drop (deploy log here.)
I then pushed it to GitHub, linked it and it is available as a deploy preview at https://60e9452e6f32a8bbd68c0676–stoic-panini-2296fb.netlify.app (deploy log here.)
In both cases though, I removed the video.
Note: there is not need for the package.json, package-lock.json or webpack.config.js files as there is nothing to build as is evidenced by the deploy preview I made after removing aforementioned files https://60e946749c263100081c8b58–stoic-panini-2296fb.netlify.app (deploy log here.)
Repository: https://github.com/coelmay/LearnNewWordsEasier-master-1
There’s a simple fix to the problem. The logs say, base directory doesn’t exist.
Your base directory is set as dist:
It should probably be your publish directory.
