- we need to know your netlify site name: pnp-netlify-serverless
Trying to follow your Intro to Serverless Functions | Netlify tutorial. When I attempt to introduce a netlify functions folder and ntl dev I get the following output.
unknown: Could not find entry: /Users/mheavers/Documents/Mozilla/Graceland/prototypes/pnp-netlify-serverless/netlify-serverless-pocket ⠇ Waiting for framework port 1234. This can be configured using the 'targetPort' property in the netlify.toml
I noticed a few issues as I attempted to follow the tutorial.
1: The ntl cli constantly gives permissions errors. You can run sudo, but if you attempt to modify the netlify.toml you cannot save it, sudo or no sudo. I had to manually (on mac) go to permissions, add my user, and configure read-write access. I couldn’t even specify the “everyone” read write permissions.
This ability is necessary, because you have to manually add the:
[functions]
node_bundler = "esbuild"
referenced in the tutorial.
Secondly, the cli on init tries to set up parcel as the default bundler. If you attempt to input the # no build command, it still will try to use parcel.
2:
Here’s the full console output:
(base) ✘ ✝ prototypes/pnp-netlify-serverless/netlify-serverless-pocket main± ntl dev
◈ Netlify Dev ◈
◈ Ignored general context env var: LANG (defined in process)
◈ Loaded function hello-world http://localhost:8888/.netlify/functions/hello-world.
◈ Functions server is listening on 49876
◈ Setting up local development server
Netlify Build
❯ Version
@netlify/build 29.1.1
❯ Flags
❯ Current directory
❯ Config file
/Users/mheavers/Documents/Mozilla/Graceland/prototypes/pnp-netlify-serverless/netlify-serverless-pocket/netlify.toml
Error: ◈ Could not create directory: /Users/mheavers/Documents/Mozilla/Graceland/prototypes/pnp-netlify-serverless/netlify-serverless-pocket/.netlify/functions-serve
at error (file:///usr/local/lib/node_modules/netlify-cli/src/utils/command-helpers.mjs:181:52)
at getTargetDirectory (file:///usr/local/lib/node_modules/netlify-cli/src/lib/functions/runtimes/js/builders/zisi.mjs:102:5)
at handler (file:///usr/local/lib/node_modules/netlify-cli/src/lib/functions/runtimes/js/builders/zisi.mjs:136:27)
at Module.getBuildFunction (file:///usr/local/lib/node_modules/netlify-cli/src/lib/functions/runtimes/js/index.mjs:40:23)
at NetlifyFunction.build (file:///usr/local/lib/node_modules/netlify-cli/src/lib/functions/netlify-function.mjs:78:27)
at FunctionsRegistry.buildFunctionAndWatchFiles (file:///usr/local/lib/node_modules/netlify-cli/src/lib/functions/registry.mjs:73:53)
Node.js v18.12.1
(base) ✘ ✝ prototypes/pnp-netlify-serverless/netlify-serverless-pocket main± sudo ntl dev
Password:
◈ Netlify Dev ◈
◈ Functions server is listening on 50268
Netlify Build
❯ Version
❯ Flags
❯ Current directory
❯ Config file
❯ Context
dev
1. Run command for local development
◈ Starting Netlify Dev with Parcel
Server running at http://localhost:1234
🚨 Build failed.
⠴ Waiting for framework port 1234. This can be configured using the 'targetPort' property in the netlify.toml
