we need to know your netlify site name: https://lauraseiler.netlify.app/
Deploy log:
2:13:56 PM: Starting post processing
2:13:56 PM: Post processing - HTML
2:13:57 PM: Post processing - header rules
2:13:57 PM: Post processing - redirect rules
2:13:57 PM: Post processing done
2:13:57 PM: Section completed: postprocessing
2:13:58 PM: Site is live ✨
Hi @nathanmartin thank you for your reply. To be exact, https://lauraseiler.netlify.app/src/#/sign-in should be running, as it’s routed to js files to display anything. That’s how it runs on my local when I execute npm run dev. But here, I have no clue how to run it. I tried to use Netlify CLI like: netlify dev:exec npm run dev but with no success tu build an app remotely
@mariusz Can you provide some more details on what you’ve built it with?
Netlify deploys static files to CDN and if you’re relying on some kind of Node based server like Express to serve routes then that will be your issue.
Edit: It may be worth mentioning that on Netlify (in the absence of any redirects) that a URL of https://lauraseiler.netlify.app/src/#/sign-in would try to load https://lauraseiler.netlify.app/src/index.html
As I’d asked before, can you provide some more details?
Are you able to provide access to the code?
Currently anyone trying to help you only has your description and the screenshot you’ve provided (which doesn’t show all the files) to try and understand your project, it’s not a lot of information.
