My site names are playbook-argon.jeffmcaleer.com and playbook-cobalt.jeffmcaleer.com
I need a preinstall step to be run before npm install gets run. I have added a preinstall script to my package.json. The preinstall script makes a modification to package.json itself as well as package-lock.json, to remove a reference to a private npm repo that Netlify doesn’t have access to. This reference is not needed when hosted on Netlify, but IS needed elsewhere so I can’t just remove it.
In the playbook-argon project, this script runs. It modifies both files, then everything works beautifully.
In the playbook-cobalt project, which is configured identically to playbook-argon, the script does not run. If I look at the build process, I can see that it goes straight to npm install and my console.log statements from the preinstall script are never run.
I’m kind of at a loss as to what I can do to make the preinstall script run. I’ve been through the docs and I can’t figure anything out.
package.json
"name": "playbook-cobalt",
"version": "1.0.0",
"private": true,
"scripts": {
"preinstall": "node setupEmulation.js",
setupEmulation.js
var fs = require("fs");
console.log("Checking to see if any patching is needed for emulation mode");
var filename;
if (process.env.EMULATION) {
filename = "package.json";
try {
// Read File
console.log(`Patching ${filename}`);
var data = fs.readFileSync(filename, "utf8");
var package = JSON.parse(data);
// Modify File
package.dependencies["@avispl/hermes-endpoint"] =
"file:./src/assets/emulation/hermes-endpoint";
// Write File
fs.writeFileSync(filename, JSON.stringify(package, null, 4));
console.log(`${filename} patching complete`);
} catch {
console.log(`Error patching ${filename}`);
filename = "package-lock.json";
try {
// Read File
if (!data) {
console.log(`${filename} not found, no patching necessary`);
} else {
var packageLock = JSON.parse(data);
// Modify File
packageLock.packages[""].dependencies["@avispl/hermes-endpoint"] =
if (packageLock.packages) {
Object.keys(packageLock.packages).forEach((package) => {
if (package.includes("hermes-endpoint")) {
delete packageLock.packages[package];
if (packageLock.dependencies) {
Object.keys(packageLock.dependencies).forEach((dependency) => {
if (dependency.includes("hermes-endpoint")) {
delete packageLock.dependencies[dependency];
// Write file
fs.writeFileSync(filename, JSON.stringify(packageLock, null, 4));
} catch {
} else {
console.log("Environment is not emulated, no patching required");
The console.log statement at the top of setupEmulation.js shows in the build logs of playbook-argon, but not in the build logs of playbook-cobalt.
I’m open to other ways to modify package.json before anything gets installed. I just need to make it reference a local file instead of a private npm repo before the install happens.
