Hi! i’m facing a build error.
2:50:56 PM: Functions bundling
2:50:56 PM: ────────────────────────────────────────────────────────────────
2:50:56 PM:
2:50:56 PM: Packaging Functions from .netlify/functions-internal directory:
2:50:56 PM: - server/server.mjs
2:50:56 PM:
2:50:56 PM: Packaging Functions from netlify/functions directory:
2:50:56 PM: - index.js
2:50:56 PM: - mailchimp.js
2:50:56 PM: - getCollections/getCollections.js
2:50:56 PM:
2:50:56 PM: ✘ [ERROR] No matching export in ".netlify/functions-internal/server/main.mjs" for import "default"
2:50:56 PM: .netlify/functions-internal/server/server.mjs:1:9:
2:50:56 PM: 1 │ export { default } from "./main.mjs";
2:50:56 PM: ╵ ~~~~~~~
2:50:56 PM:
2:50:56 PM: Bundling of function "server" failed
2:50:56 PM:
2:50:56 PM: Error message
2:50:56 PM: Build failed with 1 error:
2:50:56 PM: .netlify/functions-internal/server/server.mjs:1:9: ERROR: No matching export in ".netlify/functions-internal/server/main.mjs" for import "default"
2:50:56 PM:
2:50:56 PM: Error location
2:50:56 PM: While bundling function "server"
2:50:56 PM:
the site is https://doncactus-shopify.netlify.app
the last builds worked without any problem
the AI assistant doesn’t provide any solution.
I’ve tried updating the node version, downgradng, changing from yarn to npm, updating versions, updating netlify-cli.
if i run yarn build locally it builds.
if i run netlify build it builds.
if i run netlify depoloy it fails.
please HELP
