I am trying to create a _redirect file using data from our Sanity CMS after running next build. Here is what I’m running to build:
"build": "echo 'Building Sanity to public/studio…' && cd studio && npx sanity build ../public/studio -y && cd .. && next build && node ./public/build/generate-redirects.js"
The issue is that echo 'Building redirects...' && node ./public/build/generate-redirects.js never seems to run, therefor my _redirects file isn’t created after next build is complete. I added an echo to try to debug it, but I don’t see the echo in the build log.
Is there something I’m missing? I can generate a _redirect file locally and deploy with the static __redirects file included, but we need to be able to create this dynamically when documents are added in the CMS and the site is rebuilt remotely.
Site name: matteprojects.netlify.app
Build Log:
3:39:34 PM: build-image version: d55944c047ef0aee2ac01971edde72cb2a50acfe (focal)
3:39:34 PM: build-image tag: v4.16.1
3:39:34 PM: buildbot version: a1ec8307ac4591dcd155485cdfce7d7be735ab26
3:39:34 PM: Fetching cached dependencies
3:39:34 PM: Starting to download cache of 162.9MB
3:39:36 PM: Finished downloading cache in 1.825684982s
3:39:36 PM: Starting to extract cache
3:39:38 PM: Finished extracting cache in 1.294904048s
3:39:38 PM: Finished fetching cache in 3.169098138s
3:39:38 PM: Starting to prepare the repo for build
3:39:38 PM: Preparing Git Reference refs/heads/master
3:39:38 PM: Parsing package.json dependencies
3:39:40 PM: Starting build script
3:39:40 PM: Installing dependencies
3:39:40 PM: Python version set to 2.7
3:39:40 PM: Started restoring cached node version
3:39:40 PM: Finished restoring cached node version
3:39:41 PM: v16.19.0 is already installed.
3:39:41 PM: Now using node v16.19.0 (npm v8.19.3)
3:39:41 PM: Enabling node corepack
3:39:41 PM: Started restoring cached build plugins
3:39:41 PM: Finished restoring cached build plugins
3:39:41 PM: Attempting ruby version 2.7.2, read from environment
3:39:42 PM: Using ruby version 2.7.2
3:39:42 PM: Using PHP version 8.0
3:39:42 PM: No npm workspaces detected
3:39:42 PM: Started restoring cached node modules
3:39:42 PM: Finished restoring cached node modules
3:39:42 PM: Installing NPM modules using NPM version 8.19.3
3:39:43 PM: npm WARN EBADENGINE Unsupported engine {
3:39:43 PM: npm WARN EBADENGINE package: ‘hull@2.5.0’,
3:39:43 PM: npm WARN EBADENGINE required: { node: ‘14.x’ },
3:39:43 PM: npm WARN EBADENGINE current: { node: ‘v16.19.0’, npm: ‘8.19.3’ }
3:39:43 PM: npm WARN EBADENGINE }
3:39:45 PM: > hull@2.5.0 postinstall
3:39:45 PM: > cd studio && npm install
3:40:12 PM: npm WARN deprecated source-map-url@0.4.1: See GitHub - lydell/source-map-url: [DEPRECATED] Tools for working with sourceMappingURL comments.
3:40:12 PM: npm WARN deprecated source-map-resolve@0.5.3: See GitHub - lydell/source-map-resolve: [DEPRECATED] Resolve the source map and/or sources for a generated file.
3:40:12 PM: npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
3:40:13 PM: npm WARN deprecated acorn-dynamic-import@2.0.2: This is probably built in to whatever tool you’re using. If you still need it… idknpm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: Array.prototype.sort() - JavaScript | MDN
3:40:13 PM: npm WARN deprecated react-eyedrop@4.1.4: doesnt work
3:40:13 PM: npm WARN deprecated flatten@1.0.3: flatten is deprecated in favor of utility frameworks such as lodash.
3:40:14 PM: npm WARN deprecated extract-text-webpack-plugin@3.0.2: Deprecated. Please use GitHub - webpack-contrib/mini-css-extract-plugin: Lightweight CSS extraction plugin
3:40:14 PM: npm WARN deprecated postcss-cssnext@3.1.1: ‘postcss-cssnext’ has been deprecated in favor of ‘postcss-preset-env’. Read more at Deprecating cssnext
3:40:15 PM: npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
3:40:16 PM: npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
3:40:16 PM: npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
3:40:17 PM: npm WARN deprecated har-validator@5.1.5: this library is no longer supported
3:40:17 PM: npm WARN deprecated eslint-plugin-standard@5.0.0: standard 16.0.0 and eslint-config-standard 16.0.0 no longer require the eslint-plugin-standard package. You can remove it from your dependencies with ‘npm rm eslint-plugin-standard’. More info here: https://github.com/standard/standard/issues/1316
3:40:17 PM: npm WARN deprecated messageformat@2.3.0: Package renamed as ‘@messageformat/core’, see messageformat.github.io for more details. ‘messageformat’ will eventually provide a polyfill for Intl.MessageFormat, once it’s been defined by Unicode & ECMA.npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
3:40:18 PM: npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
3:40:18 PM: npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
3:40:19 PM: npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See There’s Math.random(), and then there’s Math.random() · V8 for details.
3:40:20 PM: npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See There’s Math.random(), and then there’s Math.random() · V8 for details.
3:40:20 PM: npm WARN deprecated urix@0.1.0: Please see GitHub - lydell/urix: [DEPRECATED] Makes Windows-style paths more unix and URI friendly.
3:40:20 PM: npm WARN deprecated resolve-url@0.2.1: GitHub - lydell/resolve-url: [DEPRECATED] Like Node.js’ `path.resolve`/`url.resolve` for the browser.
3:40:27 PM: npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
3:40:37 PM: added 2129 packages, and audited 2130 packages in 51s
3:40:37 PM: 138 packages are looking for funding
3:40:37 PM: run npm fund for details
3:40:37 PM: 79 vulnerabilities (49 moderate, 18 high, 12 critical)
3:40:37 PM: To address issues that do not require attention, run:
3:40:37 PM: npm audit fix
3:40:37 PM: To address all issues (including breaking changes), run:
3:40:37 PM: npm audit fix --force
3:40:37 PM: Run npm audit for details.
3:40:37 PM: up to date, audited 393 packages in 54s
3:40:37 PM: 37 packages are looking for funding
3:40:37 PM: 8 vulnerabilities (1 low, 1 moderate, 3 high, 3 critical)
3:40:37 PM: To address all issues, run:
3:40:37 PM: NPM modules installed
3:40:37 PM: Creating package sha
3:40:37 PM: Started restoring cached go cache
3:40:37 PM: Finished restoring cached go cache
3:40:37 PM: Installing Go version 1.17 (requested 1.17)
3:40:41 PM: unset GOOS;
3:40:41 PM: unset GOARCH;
3:40:41 PM: export GOROOT=‘/opt/buildhome/.gimme/versions/go1.17.linux.amd64’;
3:40:41 PM: export PATH=“/opt/buildhome/.gimme/versions/go1.17.linux.amd64/bin:${PATH}”;
3:40:41 PM: go version >&2;
3:40:41 PM: export GIMME_ENV=“/opt/buildhome/.gimme/env/go1.17.linux.amd64.env”
3:40:41 PM: go version go1.17 linux/amd64
3:40:42 PM: Detected 1 framework(s)
3:40:42 PM: “next” at version “12.2.3”
3:40:42 PM: Installing missing commands
3:40:42 PM: Verify run directory
3:40:42 PM: Section completed: initializing
3:40:43 PM:
3:40:43 PM: Netlify Build
3:40:43 PM: ────────────────────────────────────────────────────────────────
3:40:43 PM:
3:40:43 PM: ❯ Version
3:40:43 PM: @netlify/build 29.4.0
3:40:43 PM:
3:40:43 PM: ❯ Flags
3:40:43 PM: baseRelDir: true
3:40:43 PM: buildId: 63b5e4057479940008413889
3:40:43 PM: deployId: 63b5e405747994000841388b
3:40:43 PM:
3:40:43 PM: ❯ Current directory
3:40:43 PM: /opt/build/repo
3:40:43 PM:
3:40:43 PM: ❯ Config file
3:40:43 PM: No config file was defined: using default values.
3:40:43 PM:
3:40:43 PM: ❯ Context
3:40:43 PM: production
3:40:43 PM:
3:40:43 PM: ❯ Using Next.js Runtime - v4.29.4
3:40:44 PM:
3:40:44 PM: 1. @netlify/plugin-nextjs (onPreBuild event)
3:40:44 PM: ────────────────────────────────────────────────────────────────
3:40:44 PM:
3:40:44 PM: Next.js cache restored.
3:40:44 PM: Netlify configuration property “build.environment.NEXT_PRIVATE_TARGET” value changed.
3:40:44 PM:
3:40:44 PM: (@netlify/plugin-nextjs onPreBuild completed in 117ms)
3:40:44 PM:
3:40:44 PM: 2. Build command from Netlify app
3:40:44 PM:
3:40:44 PM: $ next build
3:40:45 PM: info - Linting and checking validity of types…
3:40:45 PM: warn - No ESLint configuration detected. Run next lint to begin setup
3:40:49 PM: info - Creating an optimized production build…
3:41:00 PM: info - Compiled successfully
3:41:00 PM: info - Collecting page data…
3:41:02 PM: info - Generating static pages (0/320)
3:41:04 PM: Warning: data for page “/journal/work” is 210 kB which exceeds the threshold of 128 kB, this amount of data can reduce performance.
3:41:04 PM: See more info here: large-page-data | Next.js
3:41:04 PM: Warning: data for page “/journal” is 263 kB which exceeds the threshold of 128 kB, this amount of data can reduce performance.
3:41:04 PM: Warning: data for page “/search” is 192 kB which exceeds the threshold of 128 kB, this amount of data can reduce performance.
3:41:05 PM: info - Generating static pages (80/320)
3:41:08 PM: Warning: data for page “/capabilities/[slug]” is 168 kB which exceeds the threshold of 128 kB, this amount of data can reduce performance.
3:41:08 PM: See more info here: large-page-data | Next.js
3:41:08 PM: Warning: data for page “/capabilities/[slug]” is 139 kB which exceeds the threshold of 128 kB, this amount of data can reduce performance.
3:41:21 PM: info - Generating static pages (320/320)
3:41:21 PM: info - Finalizing page optimization…
3:41:21 PM: Page Size First Load JS
3:41:21 PM: ┌ ● / (1880 ms) 484 B 166 kB
3:41:21 PM: ├ /_app 0 B 131 kB
3:41:21 PM: ├ ● /[…slug] (597 ms) 690 B 166 kB
3:41:21 PM: ├ └ /terms-and-conditions (597 ms)
3:41:21 PM: ├ ○ /404 (1003 ms) 564 B 166 kB
3:41:21 PM: ├ ● /about (1091 ms) 1.4 kB 167 kB
3:41:21 PM: ├ λ /api/klaviyo/newsletter-join 0 B 131 kB
3:41:21 PM: ├ λ /api/mailchimp/newsletter-join 0 B 131 kB
3:41:21 PM: ├ λ /api/preview 0 B 131 kB
3:41:21 PM: ├ λ /api/sendgrid/send-message 0 B 131 kB
3:41:21 PM: ├ ● /capabilities/[slug] (322895 ms) 43.1 kB 208 kB
3:41:21 PM: ├ ├ /capabilities/puma (11507 ms)
3:41:21 PM: ├ ├ /capabilities/netflix-music (11298 ms)
3:41:21 PM: ├ ├ /capabilities/ugg-experiential (10914 ms)
3:41:21 PM: ├ ├ /capabilities/ibm (9397 ms)
3:41:21 PM: ├ ├ /capabilities/general (9334 ms)
3:41:21 PM: ├ ├ /capabilities/genesishouse (9191 ms)
3:41:21 PM: ├ ├ /capabilities/img (9043 ms)
3:41:21 PM: ├ └ [+53 more paths] (avg 4759 ms)
3:41:21 PM: ├ ● /clients (808 ms) 997 B 163 kB
3:41:21 PM: ├ ● /clients/[slug] (27692 ms) 3.31 kB 172 kB
3:41:21 PM: ├ ├ /clients/tom-ford (451 ms)
3:41:21 PM: ├ ├ /clients/google (424 ms)
3:41:21 PM: ├ ├ /clients/les-mills (421 ms)
3:41:21 PM: ├ ├ /clients/guerlain (397 ms)
3:41:21 PM: ├ ├ /clients/yves-saint-laurent-beaute (397 ms)
3:41:21 PM: ├ ├ /clients/alexander-wang (384 ms)
3:41:21 PM: ├ ├ /clients/w-south-beach (382 ms)
3:41:21 PM: ├ └ [+75 more paths] (avg 331 ms)
3:41:21 PM: ├ ● /contact (772 ms) 796 B 163 kB
3:41:21 PM: ├ ● /journal (1720 ms) 621 B 174 kB
3:41:21 PM: ├ ● /journal/editorial (1234 ms) 626 B 174 kB
3:41:21 PM: ├ ● /journal/editorial/[slug] (54915 ms) 3.34 kB 174 kB
3:41:21 PM: ├ ├ /journal/editorial/declared (2077 ms)
3:41:21 PM: ├ ├ /journal/editorial/hell-of-a-cruise (1968 ms)
3:41:21 PM: ├ ├ /journal/editorial/q-a-with-ivan-olita (1915 ms)
3:41:21 PM: ├ ├ /journal/editorial/the-inspo-dhia-grillac (1872 ms)
3:41:21 PM: ├ ├ /journal/editorial/an-ode-to-jean-luc-godard-and-the-french-new-wave-of-film-that-came-through-him-joliamour-dubose (1864 ms)
3:41:21 PM: ├ ├ /journal/editorial/november-shows (1828 ms)
3:41:21 PM: ├ ├ /journal/editorial/la-luna (1816 ms)
3:41:21 PM: ├ └ [+31 more paths] (avg 1341 ms)
3:41:21 PM: ├ ● /journal/work (1694 ms) 627 B 174 kB
3:41:21 PM: ├ ● /journal/work/[slug] (159089 ms) 3.31 kB 174 kB
3:41:21 PM: ├ ├ /journal/work/live-fashion (2540 ms)
3:41:21 PM: ├ ├ /journal/work/aku-miami-art-basel-2021 (1981 ms)
3:41:21 PM: ├ ├ /journal/work/burberry-x-ssense-imaginary-cities (1778 ms)
3:41:21 PM: ├ ├ /journal/work/the-macallan-art-basel-miami-beach (1715 ms)
3:41:21 PM: ├ ├ /journal/work/los-angeles-club-lacoste-fw22-launch-event (1677 ms)
3:41:21 PM: ├ ├ /journal/work/yeezy (1673 ms)
3:41:21 PM: ├ ├ /journal/work/vans-somewhere-else-entirely (1670 ms)
3:41:21 PM: ├ └ [+122 more paths] (avg 1197 ms)
3:41:21 PM: ├ λ /robots.txt 332 B 131 kB
3:41:21 PM: ├ ● /search (1745 ms) 8.32 kB 177 kB
3:41:21 PM: └ λ /sitemap.xml 335 B 131 kB
3:41:21 PM: + First Load JS shared by all 131 kB
3:41:21 PM: ├ chunks/framework-dfb4b001ca8efcfd.js 45.2 kB
3:41:21 PM: ├ chunks/main-4a6b13b2591463f6.js 30.8 kB
3:41:21 PM: ├ chunks/pages/_app-33aa430c52ba97da.js 52.7 kB
3:41:21 PM: ├ chunks/webpack-33d5e40f2940d1ea.js 2.22 kB
3:41:21 PM: └ css/c083fe09dc6a7266.css 16.6 kB
3:41:21 PM: ƒ Middleware 19.7 kB
3:41:21 PM: λ (Server) server-side renders at runtime (uses getInitialProps or getServerSideProps)
3:41:21 PM: ○ (Static) automatically rendered as static HTML (uses no initial props)
3:41:21 PM: ● (SSG) automatically generated as static HTML + JSON (uses getStaticProps)
3:41:21 PM:
3:41:21 PM: (build.command completed in 36.9s)
3:41:21 PM:
3:41:21 PM: 3. @netlify/plugin-nextjs (onBuild event)
3:41:21 PM: ────────────────────────────────────────────────────────────────
3:41:21 PM:
3:41:22 PM: Patching /opt/build/repo/node_modules/next/dist/server/base-server.js
3:41:22 PM: Done
3:41:22 PM: Patching /opt/build/repo/node_modules/next/dist/server/next-server.js
3:41:22 PM: Done
3:41:22 PM: Moving static page files to serve from CDN…
3:41:22 PM: Moved 636 files
3:41:22 PM: Using Netlify Edge Functions for image format detection. Set env var “NEXT_DISABLE_EDGE_IMAGES=true” to disable.
3:41:22 PM:
Deploying middleware and functions to Netlify Edge Functions ![]()
3:41:22 PM: This feature is in beta. Please share your feedback here: Next.js on Netlify Edge Functions Beta discussion · Discussion #1319 · netlify/next-runtime · GitHub
3:41:22 PM: Netlify configuration property “redirects” value changed to [
3:41:22 PM: { from: ‘/next/static/', to: ‘/static/:splat’, status: 200 },
3:41:22 PM: {
3:41:22 PM: from: '/_next/image’,
3:41:22 PM: query: { url: ‘:url’, w: ‘:width’, q: ‘:quality’ },
3:41:22 PM: to: '/ipx/w:width,q:quality/:url’,
3:41:22 PM: status: 301
3:41:22 PM: },
3:41:22 PM: { from: ‘/_ipx/', to: ‘/.netlify/builders/_ipx’, status: 200 },
3:41:22 PM: { from: '/cache/’, to: ‘/404.html’, status: 404, force: true },
3:41:22 PM: { from: ‘/server/', to: ‘/404.html’, status: 404, force: true },
3:41:22 PM: { from: '/serverless/’, to: ‘/404.html’, status: 404, force: true },
3:41:22 PM: { from: ‘/trace’, to: ‘/404.html’, status: 404, force: true },
3:41:22 PM: { from: ‘/traces’, to: ‘/404.html’, status: 404, force: true },
3:41:22 PM: {
3:41:22 PM: from: ‘/routes-manifest.json’,
3:41:22 PM: to: ‘/404.html’,
3:41:22 PM: status: 404,
3:41:22 PM: force: true
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/build-manifest.json’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/prerender-manifest.json’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/react-loadable-manifest.json’,
3:41:22 PM: },
3:41:22 PM: { from: ‘/BUILD_ID’, to: ‘/404.html’, status: 404, force: true },
3:41:22 PM: {
3:41:22 PM: from: ‘/api/',
3:41:22 PM: to: ‘/.netlify/functions/___netlify-handler’,
3:41:22 PM: status: 200
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/_redirects’,
3:41:22 PM: to: ‘/_redirects’,
3:41:22 PM: conditions: { Cookie: [Array] },
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/build/generate-redirects.js’,
3:41:22 PM: to: ‘/build/generate-redirects.js’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/images/matte-bg.jpeg’,
3:41:22 PM: to: ‘/images/matte-bg.jpeg’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Gotham-Book.woff’,
3:41:22 PM: to: ‘/fonts/Gotham-Book.woff’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Gotham-Book.woff2’,
3:41:22 PM: to: ‘/fonts/Gotham-Book.woff2’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Grtsk-Giga-Regular.woff’,
3:41:22 PM: to: ‘/fonts/Grtsk-Giga-Regular.woff’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Grtsk-Giga-Regular.woff2’,
3:41:22 PM: to: ‘/fonts/Grtsk-Giga-Regular.woff2’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Grtsk-Mega-Medium.woff’,
3:41:22 PM: to: ‘/fonts/Grtsk-Mega-Medium.woff’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Grtsk-Mega-Medium.woff2’,
3:41:22 PM: to: ‘/fonts/Grtsk-Mega-Medium.woff2’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Grtsk-Tera-Medium-Italic.woff’,
3:41:22 PM: to: ‘/fonts/Grtsk-Tera-Medium-Italic.woff’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Grtsk-Tera-Medium-Italic.woff2’,
3:41:22 PM: to: ‘/fonts/Grtsk-Tera-Medium-Italic.woff2’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Grtsk-Tera-Regular.woff’,
3:41:22 PM: to: ‘/fonts/Grtsk-Tera-Regular.woff’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/fonts/Grtsk-Tera-Regular.woff2’,
3:41:22 PM: to: ‘/fonts/Grtsk-Tera-Regular.woff2’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/models/matte-logo.dae’,
3:41:22 PM: to: ‘/models/matte-logo.dae’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/models/matte-logo.glb’,
3:41:22 PM: to: ‘/models/matte-logo.glb’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/models/matte-logo.gltf’,
3:41:22 PM: to: ‘/models/matte-logo.gltf’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/video/matte_globe.mp4’,
3:41:22 PM: to: ‘/video/matte_globe.mp4’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: '/’,
3:41:22 PM: status: 200,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/_next/data/0L_3089GHA3fn4aRX8K6G/robots.txt.json’,
3:41:22 PM: force: false
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/robots.txt’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/_next/data/0L_3089GHA3fn4aRX8K6G/sitemap.xml.json’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/sitemap.xml’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/_next/data/0L_3089GHA3fn4aRX8K6G/capabilities/:slug.json’,
3:41:22 PM: to: ‘/server/pages/404.html’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/capabilities/:slug’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/_next/data/0L_3089GHA3fn4aRX8K6G/clients/:slug.json’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/clients/:slug’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/_next/data/0L_3089GHA3fn4aRX8K6G/journal/editorial/:slug.json’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/journal/editorial/:slug’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/_next/data/0L_3089GHA3fn4aRX8K6G/journal/work/:slug.json’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/journal/work/:slug’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/_next/data/0L_3089GHA3fn4aRX8K6G/:slug/',
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: '/:slug/’,
3:41:22 PM: },
3:41:22 PM: {
3:41:22 PM: from: ‘/*’,
3:41:22 PM: }
3:41:22 PM: ].
3:41:22 PM:
3:41:22 PM: (@netlify/plugin-nextjs onBuild completed in 299ms)
3:41:22 PM:
3:41:22 PM: 4. Functions bundling
3:41:22 PM: ────────────────────────────────────────────────────────────────
3:41:22 PM:
3:41:22 PM: Packaging Functions from .netlify/functions-internal directory:
3:41:22 PM: - ___netlify-handler/___netlify-handler.js
3:41:22 PM: - ___netlify-odb-handler/___netlify-odb-handler.js
3:41:22 PM: - _ipx/_ipx.js
3:41:22 PM:
3:41:41 PM:
3:41:41 PM: (Functions bundling completed in 19.1s)
3:41:41 PM:
3:41:41 PM: 5. Edge Functions bundling
3:41:41 PM: ────────────────────────────────────────────────────────────────
3:41:41 PM:
3:41:41 PM: Packaging Edge Functions from .netlify/edge-functions directory:
3:41:41 PM: - ipx
3:41:41 PM: - next_middleware
3:41:44 PM:
3:41:44 PM: (Edge Functions bundling completed in 2.7s)
3:41:44 PM:
3:41:44 PM: 6. @netlify/plugin-nextjs (onPostBuild event)
3:41:44 PM: ────────────────────────────────────────────────────────────────
3:41:44 PM:
3:41:44 PM: Next.js cache saved.
3:41:44 PM:
3:41:44 PM: (@netlify/plugin-nextjs onPostBuild completed in 167ms)
3:41:44 PM:
3:41:44 PM: 7. Deploy site
3:41:44 PM:
3:41:44 PM: Starting to deploy site from ‘.next’
3:41:44 PM: Creating deploy tree asynchronously
3:41:46 PM: 360 new files to upload
3:41:46 PM: 2 new functions to upload
3:41:47 PM: 0% complete
3:41:47 PM: 5% complete
3:41:47 PM: 10% complete
3:41:47 PM: 15% complete
3:41:48 PM: 20% complete
3:41:48 PM: 25% complete
3:41:48 PM: 30% complete
3:41:48 PM: 35% complete
3:41:48 PM: 40% complete
3:41:48 PM: 45% complete
3:41:48 PM: 50% complete
3:41:48 PM: 55% complete
3:41:49 PM: 60% complete
3:41:49 PM: 65% complete
3:41:49 PM: 70% complete
3:41:49 PM: 75% complete
3:41:49 PM: 80% complete
3:41:49 PM: 85% complete
3:41:49 PM: 90% complete
3:41:50 PM: 95% complete
3:41:50 PM: 100% complete
3:41:57 PM: Section completed: deploying
3:41:57 PM: Site deploy was successfully initiated
3:41:57 PM:
3:41:57 PM: (Deploy site completed in 13.5s)
3:41:57 PM:
3:41:57 PM: Netlify Build Complete
3:41:57 PM: ────────────────────────────────────────────────────────────────
3:41:57 PM:
3:41:57 PM: (Netlify Build completed in 1m 14.5s)
3:41:58 PM: Caching artifacts
3:41:58 PM: Started saving node modules
3:41:58 PM: Finished saving node modules
3:41:58 PM: Starting post processing
3:41:58 PM: Started saving build plugins
3:41:58 PM: Finished saving build plugins
3:41:58 PM: Started saving pip cache
3:41:58 PM: Finished saving pip cache
3:41:58 PM: Post processing - HTML
3:41:58 PM: Started saving emacs cask dependencies
3:41:58 PM: Finished saving emacs cask dependencies
3:41:58 PM: Started saving maven dependencies
3:41:58 PM: Finished saving maven dependencies
3:41:58 PM: Started saving boot dependencies
3:41:58 PM: Finished saving boot dependencies
3:41:58 PM: Started saving rust rustup cache
3:41:58 PM: Finished saving rust rustup cache
3:41:58 PM: Started saving go dependencies
3:41:58 PM: Finished saving go dependencies
3:41:58 PM: Build script success
3:41:58 PM: Section completed: building
3:42:01 PM: Uploading Cache of size 163.2MB
3:42:02 PM: Section completed: cleanup
3:42:02 PM: Finished processing build request in 2m27.944571207s
3:42:15 PM: Post processing - header rules
3:42:15 PM: Post processing - redirect rules
3:42:16 PM: Post processing done
3:42:16 PM: Section completed: postprocessing
3:42:20 PM: Site is live ![]()
