Site name: https://oliviahuntcello.netlify.app/
I think this might have something to with my content prop in my tailwindconfig and the purging of styles, here it is:
import typographyPlugin from '@tailwindcss/typography'
import { type Config } from 'tailwindcss'
import typographyStyles from './typography'
export default {
content: [
'./src/**/**/*.tsx',
'./src/**/*.tsx',
'./src/**/*.tsx',
'./public/**/*.html',
'./components/**/*.tsx',
'./pages/**/*.tsx'],
darkMode: 'selector',
plugins: [typographyPlugin],
theme: {
fontSize: {
xs: ['0.8125rem', { lineHeight: '1.5rem' }],
sm: ['0.875rem', { lineHeight: '1.5rem' }],
base: ['1rem', { lineHeight: '1.75rem' }],
lg: ['1.125rem', { lineHeight: '1.75rem' }],
xl: ['1.25rem', { lineHeight: '2rem' }],
'2xl': ['1.5rem', { lineHeight: '2rem' }],
'3xl': ['1.875rem', { lineHeight: '2.25rem' }],
'4xl': ['2rem', { lineHeight: '2.5rem' }],
'5xl': ['3rem', { lineHeight: '3.5rem' }],
'6xl': ['3.75rem', { lineHeight: '1' }],
'7xl': ['4.5rem', { lineHeight: '1' }],
'8xl': ['6rem', { lineHeight: '1' }],
'9xl': ['8rem', { lineHeight: '1' }],
typography: typographyStyles,
} satisfies Config
here are my logs:
Deploy log
Preview
Minimize log
Initializing
Complete
5:21:20 PM: Build ready to start
5:21:21 PM: build-image version: fcb0c1b3ada6d25c1cb58e8bc514f5f23cc14f15 (focal)
5:21:21 PM: buildbot version: b01fe4bfba24ebbf2be94776e35d0c0d9decd607
5:21:22 PM: Building without cache
5:21:22 PM: Starting to prepare the repo for build
5:21:22 PM: No cached dependencies found. Cloning fresh repo
5:21:22 PM: git clone --filter=blob:none https://github.com/ladderdesigns/oliviahuntcello.com
5:21:22 PM: Preparing Git Reference refs/heads/main
5:21:24 PM: Starting to install dependencies
5:21:24 PM: Python version set to 3.8
5:21:24 PM: Attempting Ruby version 2.7.2, read from environment
5:21:24 PM: Using Ruby version 2.7.2
5:21:25 PM: Started restoring cached go cache
5:21:25 PM: Finished restoring cached go cache
5:21:26 PM: go version go1.19.13 linux/amd64
5:21:26 PM: Using PHP version 8.0
5:21:27 PM: Downloading and installing node v20.11.0...
5:21:27 PM: Downloading https://nodejs.org/dist/v20.11.0/node-v20.11.0-linux-x64.tar.xz...
5:21:28 PM: Computing checksum with sha256sum
5:21:28 PM: Checksums matched!
5:21:30 PM: Now using node v20.11.0 (npm v10.2.4)
5:21:30 PM: Enabling Node.js Corepack
5:21:30 PM: Started restoring cached build plugins
5:21:30 PM: Finished restoring cached build plugins
5:21:30 PM: Started restoring cached corepack dependencies
5:21:30 PM: Finished restoring cached corepack dependencies
5:21:30 PM: No npm workspaces detected
5:21:30 PM: Started restoring cached node modules
5:21:30 PM: Finished restoring cached node modules
5:21:31 PM: Installing npm packages using npm version 10.2.4
5:21:44 PM: added 601 packages, and audited 602 packages in 13s
5:21:44 PM: 275 packages are looking for funding
5:21:44 PM: run `npm fund` for details
5:21:44 PM: found 0 vulnerabilities
5:21:44 PM: npm packages installed
5:21:44 PM: Successfully installed dependencies
5:21:44 PM: Starting build script
5:21:45 PM: Detected 1 framework(s)
5:21:45 PM: "next" at version "14.0.4"
5:21:45 PM: Section completed: initializing
Building
Complete
5:21:46 PM: Netlify Build
5:21:46 PM: ────────────────────────────────────────────────────────────────
5:21:46 PM:
5:21:46 PM: ❯ Version
5:21:46 PM: @netlify/build 29.33.2
5:21:46 PM:
5:21:46 PM: ❯ Flags
5:21:46 PM: baseRelDir: true
5:21:46 PM: buildId: 65c03810f775d9c8d09d7f10
5:21:46 PM: deployId: 65c03810f775d9c8d09d7f12
5:21:46 PM:
5:21:46 PM: ❯ Current directory
5:21:46 PM: /opt/build/repo
5:21:46 PM:
5:21:46 PM: ❯ Config file
5:21:46 PM: No config file was defined: using default values.
5:21:46 PM:
5:21:46 PM: ❯ Context
5:21:46 PM: production
5:21:46 PM:
5:21:46 PM: ❯ Installing plugins
5:21:46 PM: - @netlify/plugin-nextjs@4.41.3
5:21:58 PM:
5:21:58 PM: ❯ Using Next.js Runtime - v4.41.3
5:21:59 PM:
5:21:59 PM: @netlify/plugin-nextjs (onPreBuild event)
5:21:59 PM: ────────────────────────────────────────────────────────────────
5:21:59 PM:
5:21:59 PM: No Next.js cache to restore.
5:21:59 PM: Netlify configuration property "build.environment.NEXT_PRIVATE_TARGET" value changed.
5:21:59 PM:
5:21:59 PM: (@netlify/plugin-nextjs onPreBuild completed in 54ms)
5:21:59 PM:
5:21:59 PM: Build command from Netlify app
5:21:59 PM:
5:21:59 PM: $ npm run build
5:21:59 PM: > tailwindui-template@0.1.0 build
5:21:59 PM: > next build
5:22:00 PM: ⚠ No build cache found. Please configure build caching for faster rebuilds. Read more: https://nextjs.org/docs/messages/no-cache
5:22:00 PM: ▲ Next.js 14.0.4
5:22:00 PM: Creating an optimized production build ...
5:22:06 PM: ✓ Compiled successfully
5:22:06 PM: Linting and checking validity of types ...
5:22:10 PM: Collecting page data ...
5:22:12 PM: Generating static pages (0/15) ...
5:22:13 PM: Generating static pages (3/15)
5:22:13 PM: Generating static pages (7/15)
5:22:13 PM: Generating static pages (11/15)
5:22:13 PM: ✓ Generating static pages (15/15)
5:22:13 PM: Finalizing page optimization ...
5:22:13 PM: Collecting build traces ...
5:22:18 PM: Route (app) Size First Load JS
5:22:18 PM: ┌ ○ / 5.88 kB 99.5 kB
5:22:18 PM: ├ ○ /_not-found 0 B 0 B
5:22:18 PM: ├ ○ /about 667 B 94.3 kB
5:22:18 PM: ├ ○ /articles 3.44 kB 92.1 kB
5:22:18 PM: ├ λ /articles/the-art-of-cello-bowing 3.43 kB 85.3 kB
5:22:18 PM: ├ λ /articles/the-resonance-of-sharp-notes 3.43 kB 85.3 kB
5:22:18 PM: ├ ○ /contact 181 B 88.8 kB
5:22:18 PM: ├ λ /feed.xml 0 B 0 B
5:22:18 PM: ├ ○ /lessons 662 B 94.3 kB
5:22:18 PM: ├ ○ /projects 393 B 94 kB
5:22:18 PM: ├ ○ /thank-you 138 B 82 kB
5:22:18 PM: └ ○ /uses 181 B 88.8 kB
5:22:18 PM: + First Load JS shared by all 81.9 kB
5:22:18 PM: ├ chunks/938-97a4c5fe53c20fb7.js 26.7 kB
5:22:18 PM: ├ chunks/fd9d1056-e9a01193b1822c33.js 53.3 kB
5:22:18 PM: ├ chunks/main-app-99645ed85d33f049.js 220 B
5:22:18 PM: └ chunks/webpack-d3261d7ee3a60fb2.js 1.68 kB
5:22:18 PM: ○ (Static) prerendered as static content
5:22:18 PM: λ (Dynamic) server-rendered on demand using Node.js
5:22:18 PM:
5:22:18 PM: (build.command completed in 18.5s)
5:22:18 PM:
5:22:18 PM: @netlify/plugin-nextjs (onBuild event)
5:22:18 PM: ────────────────────────────────────────────────────────────────
5:22:18 PM:
5:22:18 PM: Moving static page files to serve from CDN...
5:22:18 PM: Moved 20 files to CDN
5:22:18 PM: You are not using Netlify Edge Functions for image format detection. Set env var "NEXT_FORCE_EDGE_IMAGES=true" to enable.
5:22:18 PM: Netlify configuration property "redirects" value changed to [
5:22:18 PM: { from: "/_next/static/*", to: "/static/:splat", status: 200 },
5:22:18 PM: {
5:22:18 PM: from: "/_next/image*",
5:22:18 PM: query: { url: ":url", w: ":width", q: ":quality" },
5:22:18 PM: to: "/_ipx/w_:width,q_:quality/:url",
5:22:18 PM: status: 301
5:22:18 PM: },
5:22:18 PM: { from: "/_ipx/*", to: "/.netlify/builders/_ipx", status: 200 },
5:22:18 PM: {
5:22:18 PM: from: "/api/*",
5:22:18 PM: to: "/.netlify/functions/___netlify-handler",
5:22:18 PM: status: 200
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: from: "/*",
5:22:18 PM: status: 200,
5:22:18 PM: conditions: { Cookie: [Array] },
5:22:18 PM: force: true
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: from: "/_next/data/piWXAyrVofKyk1BsQGnbJ/_not-found.json",
5:22:18 PM: force: false
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: from: "/_not-found",
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: from: "/_next/data/piWXAyrVofKyk1BsQGnbJ/articles/the-art-of-cello-bowing.json",
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: from: "/articles/the-art-of-cello-bowing",
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: from: "/_next/data/piWXAyrVofKyk1BsQGnbJ/articles/the-resonance-of-sharp-notes.json",
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: from: "/articles/the-resonance-of-sharp-notes",
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: from: "/_next/data/piWXAyrVofKyk1BsQGnbJ/feed.xml.json",
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: from: "/feed.xml",
5:22:18 PM: },
5:22:18 PM: {
5:22:18 PM: }
5:22:18 PM: ].
5:22:18 PM:
5:22:18 PM: (@netlify/plugin-nextjs onBuild completed in 151ms)
5:22:18 PM:
5:22:18 PM: Functions bundling
5:22:18 PM:
5:22:18 PM: Packaging Functions from .netlify/functions-internal directory:
5:22:18 PM: - ___netlify-handler/___netlify-handler.js
5:22:18 PM: - ___netlify-odb-handler/___netlify-odb-handler.js
5:22:18 PM: - _ipx/_ipx.js
5:22:18 PM:
5:22:35 PM:
5:22:35 PM: (Functions bundling completed in 17s)
5:22:35 PM:
5:22:35 PM: Edge Functions bundling
5:22:35 PM: ────────────────────────────────────────────────────────────────
5:22:35 PM:
5:22:35 PM: Packaging Edge Functions from .netlify/edge-functions directory:
5:22:35 PM: - rsc-data
5:22:37 PM:
5:22:37 PM: (Edge Functions bundling completed in 2.4s)
5:22:37 PM:
5:22:37 PM: @netlify/plugin-nextjs (onPostBuild event)
5:22:37 PM: ────────────────────────────────────────────────────────────────
5:22:37 PM:
5:22:38 PM: Next.js cache saved.
5:22:38 PM:
5:22:38 PM: (@netlify/plugin-nextjs onPostBuild completed in 261ms)
5:22:38 PM:
5:22:45 PM: (Netlify Build completed in 58.3s)
5:23:05 PM: Section completed: building
5:23:08 PM: Finished processing build request in 1m46.921s
Deploying
Complete
5:22:38 PM: Deploy site
5:22:38 PM: ────────────────────────────────────────────────────────────────
5:22:38 PM:
5:22:38 PM: Starting to deploy site from ".next"
5:22:38 PM: Calculating files to upload
5:22:38 PM: 22 new files to upload
5:22:38 PM: 2 new functions to upload
5:22:45 PM: Section completed: deploying
5:22:45 PM: Site deploy was successfully initiated
5:22:45 PM:
5:22:45 PM: (Deploy site completed in 6.8s)
Cleanup
Complete
5:22:45 PM: Netlify Build Complete
5:22:45 PM: ────────────────────────────────────────────────────────────────
5:22:45 PM:
5:22:45 PM: Caching artifacts
5:22:45 PM: Started saving node modules
5:22:45 PM: Finished saving node modules
5:22:45 PM: Started saving build plugins
5:22:45 PM: Finished saving build plugins
5:22:45 PM: Started saving corepack cache
5:22:45 PM: Finished saving corepack cache
5:22:45 PM: Started saving pip cache
5:22:45 PM: Finished saving pip cache
5:22:45 PM: Started saving emacs cask dependencies
5:22:45 PM: Finished saving emacs cask dependencies
5:22:45 PM: Started saving maven dependencies
5:22:45 PM: Finished saving maven dependencies
5:22:45 PM: Started saving boot dependencies
5:22:45 PM: Finished saving boot dependencies
5:22:45 PM: Started saving rust rustup cache
5:22:45 PM: Finished saving rust rustup cache
5:22:45 PM: Started saving go dependencies
5:22:45 PM: Finished saving go dependencies
5:23:05 PM: Build script success
5:23:06 PM: Uploading Cache of size 349.1MB
5:23:08 PM: Section completed: cleanup
Post-processing
Complete
5:22:45 PM: Skipping form detection
5:22:45 PM: Post processing - header rules
5:22:45 PM: Starting post processing
5:22:45 PM: Site is live ✨
5:22:45 PM: Post processing - redirect rules
5:22:45 PM: Post processing done
5:22:45 PM: Section completed: postprocessing
