Hello. For a few days, I was having trouble deploying my Next JS project that I was localizing with i18n. Until yesterday. Yesterday I was able to publish my project on Vercel (though I’m not quite sure how I did it). But I want to be able to publish my project in places like Netlify, Cloudflare. Any ideas on what I should do about this?
As far as I know, Next JS does not support exporting projects containing i18n. However, my project is still able to be published in Vercel. What is the reason I can do this in Vercel but not in other places? What should I do?
3:09:19 AM: {
3:09:19 AM: runtimeError: {
3:09:19 AM: code: 'ERRORED_DOCUMENT_REQUEST',
3:09:19 AM: message: 'Lighthouse was unable to reliably load the page you requested. Make sure you are testing the correct URL and that the server is properly responding to all requests. (Status code: 404)'
3:09:19 AM: }
3:09:19 AM: }
3:09:19 AM: Report collected: audited_uri: 'out/', html_report_size: 314.9 KiB
3:09:19 AM:
3:09:19 AM: (@netlify/plugin-lighthouse onPostBuild completed in 5.8s)
3:09:19 AM:
3:09:19 AM: 5. @netlify/plugin-nextjs (onPostBuild event)
3:09:19 AM: ────────────────────────────────────────────────────────────────
3:09:19 AM:
3:09:19 AM: Next.js cache saved.
3:09:19 AM:
3:09:19 AM: (@netlify/plugin-nextjs onPostBuild completed in 209ms)
3:09:19 AM:
3:09:19 AM: 6. Deploy site
3:09:19 AM:
3:09:19 AM: Section completed: deploying
3:09:19 AM:
3:09:19 AM: Configuration error
3:09:19 AM:
3:09:19 AM: Error message
3:09:19 AM: Deploy did not succeed: Deploy directory 'out' does not exist
3:09:19 AM:
3:09:19 AM: Resolved config
3:09:19 AM: build:
3:09:19 AM: command: npm run build
3:09:19 AM: commandOrigin: ui
3:09:19 AM: environment:
3:09:19 AM: - NETLIFY_NEXT_PLUGIN_SKIP
3:09:19 AM: publish: /opt/build/repo/out
3:09:19 AM: publishOrigin: ui
3:09:19 AM: plugins:
3:09:19 AM: - inputs: {}
3:09:19 AM: origin: ui
3:09:19 AM: package: '@netlify/plugin-lighthouse'
3:09:19 AM: package: '@netlify/plugin-nextjs'
3:09:20 AM: Caching artifacts
3:09:20 AM: Started saving node modules
3:09:20 AM: Finished saving node modules
3:09:20 AM: Started saving build plugins
3:09:20 AM: Finished saving build plugins
3:09:20 AM: Started saving corepack cache
3:09:20 AM: Finished saving corepack cache
3:09:20 AM: Started saving pip cache
3:09:20 AM: Finished saving pip cache
3:09:20 AM: Started saving emacs cask dependencies
3:09:20 AM: Finished saving emacs cask dependencies
3:09:20 AM: Started saving maven dependencies
3:09:20 AM: Finished saving maven dependencies
3:09:20 AM: Started saving boot dependencies
3:09:20 AM: Finished saving boot dependencies
3:09:20 AM: Started saving rust rustup cache
3:09:20 AM: Finished saving rust rustup cache
3:09:20 AM: Started saving go dependencies
3:09:20 AM: Finished saving go dependencies
3:09:20 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
3:09:20 AM: Failing build: Failed to build site
3:09:20 AM: Finished processing build request in 50.286s
