Netlify web UI doesn't push environment variables to my project when running "netlify dev"
Hi.
I’m using the web UI to create several environment variables. But they are not showing up in yellow in the output when I run netlify dev.
Can anyone help??
@fool, @Dennis, @futuregerald
hey there berni,
Which version of netlify dev are you using?
Your best option to get help with netlify dev beyond the basics is to review the issues here:
if your problem isn’t in the issues, you could file a new one for the dev/CLI team to review :wink:
Hi @perry,
I’m using version 2.47.0. I’ll also take a look at the issues.
:smiley_cat:
