Injected build settings env var: DEPRECATED
Hi, checking in to see what might be the cause of some new dev-breaking behavior we are seeing when running netlify dev – it seems like none of the environmental variables that are registered in the Netlify UI admin for our site (https://paverops.netlify.app/) are being pulled on dev.
The stage and prod versions both seem to run fine, but in dev the same env vars are returning undefined. Looking closely, I can see that where normally we would see env var loading confirmation, there is a deprecation message instead:
◈ Netlify Dev ◈
◈ Injected build settings env var: DEPRECATED
◈ Ignored general context env var: LANG (defined in process)
◈ Loaded function clear-visible-areas-background.
◈ Loaded function export-layer-background.
◈ Loaded function generate-views-background.
◈ Loaded function get-app-token.
◈ Loaded function get-s3-file.
◈ Loaded function get-s3-presigned.
◈ Loaded function post-process-data-background.
◈ Loaded function publish-data.
◈ Loaded function schedule-index-rebuild-background.
◈ Loaded function send-email.
◈ Loaded function update-visible-areas-background.
◈ Loaded function upload-data-background.
◈ Loaded function upload-drawing.
◈ Loaded function verify-user.
◈ Functions server is listening on 52953
◈ Starting Netlify Dev with Gatsby
Any idea what I’m doing wrong here?
Update: running netlify env:list shows this output:
netlify env:list
site: paverops
|                                                             Environment variables                                                             |
|    Key     |                                                              Value                                                               |
| GATSBY_ENV | prod        |
| DEPRECATED | Please use the new environment variable endpoints outlined here: https://docs.netlify.com/api/get-started/#environment-variables |
And that link from the DEPRECATED line drops me at a page that describes how to use the Netlify API to request env vars. Surely this doesn’t mean I need to request each individual env var from the API does it? It would be easier just to keep a separate .env file, even though that seems like bad practice.
What version of Netlify CLI are you using?
netlify-cli/6.14.16 darwin-x64 node-v14.16.0
Would an upgrade potentially solve this?
Netlicy CLI v6 is ancient. Current latest is 15. Please upgrade!
@ewags I’m having similar issues and upgraded Netlify CLI also…but still the environment variables aren’t happy…have you had any luck? If so, what did you do?
When you try upgrading what happens? Can you post a screenshot? Here is some documentation on how to.
