Netlify not building my site with Hugo modules
This is not really a problem any longer.
What I was trying to do was create a site using Hugo Modules for my theme. When Netlify tried to build the site it failed every time. I then deleted my github repo and created a new one with the same name. I then created a new Hugo site with the same name but without adding any modules. I installed my theme “ANANKE” in the theme directory and now Netlify is able to build it correctly after I removed some files from the theme.
So, my opinion is DO NOT USE HUGO MODULES IF USING NETLIFY FOR BUILDS.
Hope this helps someone else with the same problem.
Sorry to hear about your problems. I have sites using Hugo modules that build with no issues on Netlify.
