It seems that since mid January, Netlify is treating requests from the Google Search index bot differently, breaking sites in severe ways; my website has completely fallen out from the Google Index!
This graph from the Google Search console shows when the problem started appearing; around that time nothing about my site has changed:
For example for the main page of my site, https://www.joachim-breitner.de/blog, it would report “error due to redirections”. But there is no redirect happening!
The helpful people at the Google Search Community solved the puzzle: It seems that Netlify is behaving differently if the user agent is Googlebot Smartphone! In particular, it seems to be ignoring the edge functions and instead applies some other, contradicting URL normalization, which of course completely breaks the site. Compare
- https://view.hugo-decoded.be/?scheme=https&url=www.joachim-breitner.de%2Fblog&ua=Googlebot+Smartphone&ref=None
A very likely related, and also somewhat serious issue is that the _headers file seems to be ignored for that user agent, compare
- https://view.hugo-decoded.be/?scheme=https&url=alt2.joachim-breitner.de%2F&ua=Googlebot+Smartphone&ref=None
- https://view.hugo-decoded.be/?scheme=https&url=alt2.joachim-breitner.de%2F&ref=None
where I am using _headers to set x-robots-tag: noindex, but if that setting isn’t effective precisely when Google is requesting the page, then that has a certain irony to it.
This very strongly points towards a problem within Netlify, and a severe one at that, as it can cause sites to becomes unfindable on Google. Is there a swift fix possible? Or would Netlify users somehow have to live with that?
