Site: hockey-etc.netlify.app
Our contact form uses web-components from lion. The components are imported via js and then used in an eleventy njk file.
I kind of expected to just be able to write the form normally, as i’m not completely rendering it with JS but I had to end up going the duplicated form method to get submissions pulling through properly.
Is that expected?
My code:
<form name='contact' netlify-honeypot="bot-field" netlify hidden>
<input name="bot-field"/>
<input type='text' name='first_name' />
<input type='text' name='last_name' />
<input type='email' name='email' />
<select name="department">
<option selected hidden value>Select department/team</option>
</select>
<textarea name='message'></textarea>
</form>
<div class="...">
<lion-form class="...">
<form name="contact" class="..." method="POST" onsubmit="this._submit()" netlify>
<input type='hidden' name='contact' value='contact' />
<input type="hidden" name="subject" value="... Contact Us Submission" />
{% set required_m = 'required_m' | getDatasourceForLangByName(locale) %}
{% set required_f = 'required_f' | getDatasourceForLangByName(locale) %}
<etc-input name="first_name" label="{{ 'first_name' | getDatasourceForLangByName(locale) }}" class="..." required>
<span slot="help-text">({{ required_m }})</span>
</etc-input>
<etc-input name="last_name" label="{{ 'last_name' | getDatasourceForLangByName(locale) }}" class="..." autocomplete="family-name" required>
</etc-input>
</form>
</lion-form>
</div>
