- We need to know your netlify site name.
tv-devsite.netlify.app
- DNS issues? no custom domain
- Build problems? netlify deploy problem using CI CD pipeline in gitlab
The pipeline steps in details:
#stored auth token variable in CI CD variables section and exported as well when running pipeline
- export NETLIFY_AUTH_TOKEN=“$NETLIFY_AUTH_TOKEN”
run sites list to confirm authentication
this step works fine and displays all my site IDs
run netlify deployment
netlify deploy \ --site=“30074e84-2732-4f8c-a56f-a5f6af89fd96” \ --prod
this fails with error
Error: Project not found. Please rerun “netlify link”
this is a linux machine running docker image node:24
need some help here to troubleshoot, site id is 30074e84-2732-4f8c-a56f-a5f6af89fd96
I don’t know if this helps, I’m able to run the deployment now,
this is what I changed
using
rm -rf .netlify
in the steps before starting build
using an auth check condition like this
netlify sites:list || { echo "Auth failed"; exit 1; }
to verify that auth token loaded from CICD pipeline library properly when the pipeline starts
I’ve run two other extra commands
netlify unlink
netlify link --id $NETLIFY_SITE_ID
Also as a last step clean runner caches in the pipelines menu in gitlab
The steps did not work reliably, turn out there is more to this.
It worked few times but started failing consistently again and again.
I will wait for a solution to this.
this is finally solved, the firewall was blocking access to
api.netlifysdk.com
dl.deno.land
also allow
api.netlify.com
these will solve the problem of error like “Error: Project not found. Please rerun “netlify link””
