After looking for several hours, I don’t find any answer to my issue that look so simple but go in deep behaviour of great tools.
I use the deploy preview of my project here https://deploy-preview-2--staging-togetherdo.netlify.app/ and I have the error in console netlify.js: container not found. that I totally get because actually the all Netlify inserted tag is remove somewhere in the process! I know this because in sources of dev console I see the tag, but in resulted elements after loading, the div has disappeared (cf screenshots attached).
Do you have any ideas why this could happened ?
What I have tried so far:
Make a div around my root app element
Waiting for DOMContentLoaded before mounting the app
Therefore, when my app was mounted, the Netlify div was inside the div of mount and erased.
I don’t know why this is happening though. If you have the specification for that I’d be glad to have the info (not related to Netlify but could be cool to know)
Thanks so much for coming back and sharing your solution! It will definitely be helpful for Forums members who encounter the same obstacle. I cannot speak to why this has happened, but I will leave this thread open to comments so that anyone with further insights can chime in.
Happy building, and thanks again for sharing this!
