Hello,
I have an issue with a project that we deployed to Netlify a long time ago.
The domain is tram.tradokk.com .
Basically, I need to undeploy and close that project. Unfortunately, the employee who deployed that application is no longer working here. I have tried to contact him, but to no avail. Furthermore, it seems like the email he used to create that project was not his work email.
I can verify that I am the owner of that domain. I would just like to delete that project. How can we proceed?
Regards,
Besjan
@besjan.saidi To verify the domain you can follow the steps in this support guide:
Last Reviewed by Netlify Support Staff: September 2023
Are you receiving the error “another site is using this domain” when you are trying to add your production domain to your netlify site?
Read on! This is easy to fix.
This occurs when you are trying to add a production domain that already exist on Netlify under a different account.
Do you know who might be using the domain (maybe a previous collaborator or an agency you’ve worked with in the past?), the quickest way to get this resolved i…
The Text/Value in this case would be the ID of this thread, which is 113554
Once verified a Netlify Support Team member would be able to assist.
Hey @besjan.saidi , Nathan provided you the correct details! Please let us know when your TXT record is ready so we can verify! Thanks!
@nathanmartin I verified the domain.
@besjan.saidi I can’t help you any further as I’m just a lowly community member , but @charlottechhum will get you sorted out.
Best of luck!
Melvin
March 1, 2024, 4:24pm
8
Hi @besjan.saidi ,
Thanks for updating. I’ve verified the TXT Record, you should be able to add the subdomain now.
