I need advice to debug deploy https://app.netlify.com/sites/relaxed-bassi-8a3720/deploys/5f7d32b8f41607532edbbce8
I am getting an exit status 128.
I thought it might’ve been a theme issue, so I made a new Hugo site and installed a different theme. I updated the “baseurl” and had the theme installed from gitmodule. I revoked Netlify access and reauthorized. Nothing has worked based on existing advice in the forums.
The site works locally when I test it with ‘hugo server’. So the issue should be retrieving it from GitLab.
11:15:04 PM: Build ready to start
11:15:06 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
11:15:06 PM: build-image tag: v3.4.1
11:15:06 PM: buildbot version: c6376102eedf4be6c6e5d685c7141e2eb612d47d
11:15:06 PM: Fetching cached dependencies
11:15:06 PM: Failed to fetch cache, continuing with build
11:15:06 PM: Starting to prepare the repo for build
11:15:08 PM: No cached dependencies found. Cloning fresh repo
11:15:08 PM: git clone git@gitlab.com:janezhgw/oct620-2
11:15:09 PM: Preparing Git Reference refs/heads/master
11:15:10 PM: Error checking out submodules: fatal: No url found for submodule path ‘themes/hugo-hero-theme’ in .gitmodules
11:15:10 PM: Failing build: Failed to prepare repo
11:15:10 PM: Failed during stage ‘preparing repo’: Error checking out submodules: fatal: No url found for submodule path ‘themes/hugo-hero-theme’ in .gitmodules
: exit status 128
11:15:10 PM: Finished processing build request in 3.895407933s
