Need Help: Slow Build Times and Deployment Issues on Netlify
Hi everyone,
I’m experiencing an issue with the build time for my site afnizarnur.netlify.app on Netlify. The deploy build is taking more than 15 minutes to complete. Before this, I encountered numerous deploy failures with every attempt I made to fix them. Eventually, I added the NPM_FLAGS environment variable with the value --force, which allowed the deployment to succeed. However, the build time remains very long.
My site is built using Eleventy, and I suspect the issue might be related to the Netlify CLI. Since my site uses the Netlify CLI, I tried downgrading the version in package.json as well as the Node.js version in the Netlify settings, but these changes didn’t improve the situation. I also attempted to move the Netlify CLI to devDependencies, but that didn’t help either.
Here the link to latest Deploy Log Succeeded with NPM_FLAGS
Below is my package.json, which might provide some insights:
package.json
“name”: “afnizarnur”,
“version”: “1.0.0”,
“description”: “Afnizar Nur Ghifari”,
“browserslist”: [
“defaults”
“scripts”: {
“start”: “npm run dev”,
“dev”: “run-s clean eleventy:dev --print-label”,
“build”: “run-s clean eleventy:prod --print-label”,
“eleventy:dev”: “cross-env ELEVENTY_ENV=development eleventy --serve”,
“eleventy:prod”: “cross-env ELEVENTY_ENV=production eleventy”,
“clean”: “del-cli dist”,
“test”: “echo "Error: no test specified" && exit 1”
“repository”: {
“type”: “git”,
“url”: “GitHub - afnizarnur/afnizarnur.com: My personal site handcrafted with Eleventy and hosted in Netlify.
“author”: “Afnizar Nur Ghifari”,
“license”: “MIT”,
“dependencies”: {
@11ty/eleventy-img”: “^1.0.0”,
@11ty/eleventy-navigation”: “^0.3.2”,
@11ty/eleventy-plugin-rss”: “^1.1.2”,
@babel/plugin-transform-runtime”: “^7.16.4”,
“axios”: “^1.4.0”,
“babel-loader”: “^8.2.3”,
“cheerio”: “^1.0.0-rc.12”,
“clean-css”: “^5.2.2”,
“critical”: “^5.1.1”,
“cssesc”: “^3.0.0”,
“del-cli”: “^4.0.1”,
“dotenv”: “^16.1.4”,
“eleventy-plugin-embed-everything”: “^1.18.2”,
“eleventy-plugin-svg-sprite”: “^1.2.2”,
“focus-trap”: “^6.9.4”,
“focus-visible”: “^5.2.0”,
“gsap”: “^3.9.1”,
“html-minifier”: “^4.0.0”,
“imagesloaded”: “^4.1.4”,
“lodash”: “^4.17.21”,
“luxon”: “^2.1.1”,
“markdown-it”: “^12.2.0”,
“markdown-it-footnote”: “^4.0.0”,
“memfs”: “^3.4.0”,
“netlify-cli”: “^17.23.1”,
“node-fetch”: “^3.3.1”,
“node-sass”: “npm:sass@^1.67.0”,
“npm-run-all”: “^4.1.5”,
“split-type”: “^0.3.3”,
“splitting”: “^1.0.6”,
“svg-sprite”: “^1.2.19”,
“webpack”: “^5.64.4”
“devDependencies”: {
@11ty/eleventy”: “^2.0.1”,
@11ty/eleventy-plugin-syntaxhighlight”: “^5.0.0”,
@babel/core”: “^7.22.5”,
@babel/plugin-transform-modules-commonjs”: “^7.22.5”,
@babel/preset-env”: “^7.22.5”,
“cross-env”: “^7.0.3”,
“dotenv-webpack”: “^8.0.1”,
“eleventy-plugin-page-assets”: “github:maxboeck/eleventy-plugin-page-assets”,
“plur”: “^5.1.0”,
“prettier”: “^2.8.8”
I would greatly appreciate any suggestions or solutions to improve the build time.
Thank you for your help!
@afnizarnur
time between these points in the log:
0 seconds
5:24:43 PM: Build ready to start
23 seconds
5:25:06 PM: build-image version: ... (focal)
40 seconds
5:25:46 PM: npm WARN deprecated gauge@3.0.2: This package is no longer supported.
13 minutes, 21 seconds
5:39:07 PM: npm WARN deprecated domexception@2.0.1: Use your platform's native DOMException instead
34 seconds
5:39:41 PM: $ npm run build
14 seconds
5:39:55 PM: (build.command completed in 13.8s)
The time is basically all in the dependency installation.
