I have tried to deploy my express project on netlify(doesn’t have any frontend). I have followed this tutorial - tutorial but I was facing an issue at the build time
6:10:44 PM: Netlify Build
6:10:44 PM: ────────────────────────────────────────────────────────────────
6:10:44 PM:
6:10:44 PM: ❯ Version
6:10:44 PM: @netlify/build 29.58.3
6:10:44 PM:
6:10:44 PM: ❯ Flags
6:10:44 PM: accountId: 678a602a81665b006edfb731
6:10:44 PM: baseRelDir: true
6:10:44 PM: buildId: 678ba1081da0899354e11f8a
6:10:44 PM: deployId: 678ba1081da0899354e11f8c
6:10:44 PM:
6:10:44 PM: ❯ Current directory
6:10:44 PM: /opt/build/repo
6:10:44 PM:
6:10:44 PM: ❯ Config file
6:10:44 PM: /opt/build/repo/netlify.toml
6:10:44 PM:
6:10:44 PM: ❯ Context
6:10:44 PM: production
6:10:44 PM:
6:10:44 PM: Build command from Netlify app
6:10:44 PM:
6:10:44 PM: $ npm run build
6:10:44 PM: > backend@1.0.0 build
6:10:44 PM: > netlify deploy --prod
6:10:46 PM: Logging into your Netlify account…
6:10:46 PM: Opening netlify
response_type=ticket&ticket=f53aabbdce99ff481c3ce29c23383132
6:10:46 PM: - Waiting for authorization…
6:15:46 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for nocode changes)
6:15:46 PM: › Error: Timed out waiting for authorization. If you do not have a Netlify account, please create one at , then run netlify login again.
6:15:46 PM:
6:15:46 PM: “build.command” failed
6:15:46 PM: ────────────────────────────────────────────────────────────────
6:15:46 PM:
6:15:46 PM: Error message
6:15:46 PM: Command failed with exit code 1: npm run build (exit-code-1)
6:15:46 PM:
6:15:46 PM: Error location
6:15:46 PM: In Build command from Netlify app:
6:15:46 PM: npm run build
6:15:46 PM:
6:15:46 PM: Resolved config
6:15:46 PM: build:
6:15:46 PM: command: npm run build
6:15:46 PM: commandOrigin: ui
6:15:46 PM: publish: /opt/build/repo/dist
6:15:46 PM: publishOrigin: ui
6:15:46 PM: functionsDirectory: /opt/build/repo/functions
6:15:46 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
6:15:46 PM: Failing build: Failed to build site
6:15:47 PM: Finished processing build request in 5m43.296s
and when I tried to deploy using ‘npm un build’ command locally I was getting this error
❯ Context
Finished uploading blobs to deploy store
No cached functions were found
⠴ Hashing index.html › Warning:
“code”: “MODULE_NOT_FOUND”,
“requireStack”: [
“/Users/pinreddy/.nvm/versions/node/v20.17.0/lib/node_modules/netlify-cli/node_modules/@netlify/zip-it-and-ship-it/dist/runtimes/node/bundlers/zisi/resolve.js”
› Error: In file “/Users/pinreddy/Desktop/foodCourt/backend/functions/app.js”
Cannot find module ‘call-bound’
Require stack:
- /Users/pinreddy/.nvm/versions/node/v20.17.0/lib/node_modules/netlify-cli/node_modules/@netlify/zip-it-and-ship-it/dist/runtimes/node/bundlers/zisi/resolve.js
can someone check on this I tried - fix but had no luck.
I am attaching my repo link - https://github.com/harshavardhanpinnapureddy/foodcourt/tree/backend_db
