I’m stuck at the attached screen for manual deploys since long time. deploy log says:
Creating deploy upload records
The build is not failing but its stuck. I’m using Publii and double checked all credentials. Am I doing something wrong?
Hey there, @wittymonkey
Sorry to hear you are encountering obstacles!
This Support Guide contains a ton of useful debugging tips that can likely help you solve your problem Additionally, this Support Guide houses all of our resources for debugging build and deploy issues, including “stuck at uploading” issues!
We also recommend trying to search the forums with the build error you encountered - it’s likely your question was already asked by someone else!
If you are still having problems, please provide as much information as you can, such as your site URL, what you have already tried, what your build settings are, your package.json
, etc. Thanks!
