Hello everyone, heres my answers to the “help building a good post guide”:
We need to know your netlify site name. Example:
havent gotten to it to deploy even once yet, so no site name. -
DNS issues? Tell us the custom domain, tell us the error message!
no custom domain so far -
Build problems? Link or paste the FULL build log & build settings screenshot:
Did you try Ask Netlify, our generative AI chatbot, before posting? Yes.
Here is the logs:
3:50:45 PM: build-image version: e4c0a4cdfbecca2a7c3f744f70ce2f9297335459 (noble-new-builds)3:50:45 PM: buildbot version: 4e72bc3e8a7c135b5663400784e42b17eeb1c535
3:50:45 PM: Fetching cached dependencies
3:50:45 PM: Failed to fetch cache, continuing with build
3:50:45 PM: Starting to prepare the repo for build
3:50:46 PM: No cached dependencies found. Cloning fresh repo
3:50:46 PM: git clone --filter=blob:none https://github.com/Dizzyggs/legacyrp
3:50:46 PM: Preparing Git Reference refs/heads/main
3:50:50 PM: Custom functions path detected. Proceeding with the specified path: ‘netlify/functions’
3:50:50 PM: Starting to install dependencies
3:50:50 PM: mise ~/.config/mise/config.toml tools: python@3.14.2
3:50:50 PM: mise ~/.config/mise/config.toml tools: ruby@3.4.8
3:50:51 PM: mise ~/.config/mise/config.toml tools: go@1.25.5
3:50:51 PM: v22.21.1 is already installed.
3:50:51 PM: Now using node v22.21.1 (npm v10.9.4)
3:50:52 PM: Enabling Node.js Corepack
3:50:52 PM: Started restoring cached build plugins
3:50:52 PM: Finished restoring cached build plugins
3:50:52 PM: Started restoring cached corepack dependencies
3:50:52 PM: Finished restoring cached corepack dependencies
3:50:52 PM: No npm workspaces detected
3:50:52 PM: Started restoring cached node modules
3:50:52 PM: Finished restoring cached node modules
3:50:52 PM: Installing npm packages using npm version 10.9.4
3:52:04 PM: Failed during stage ‘Install dependencies’: dependency_installation script returned non-zero exit code: 1
3:52:04 PM: npm warn deprecated node-domexception@1.0.0: Use your platform’s native DOMException instead
npm error Exit handler never called!3:52:04 PM: npm error This is an error with npm itself. Please report this error at:
3:52:04 PM: npm error <https://github.com/npm/cli/issues>
3:52:04 PM: npm error A complete log of this run can be found in: /opt/buildhome/.npm/_logs/2026-01-09T14_50_52_228Z-debug-0.log
3:52:04 PM: Error during npm install
3:52:04 PM: Failing build: Failed to install dependencies
```Im running node version 22.
My toml file:
i ran netlify build locally on my pc, and it ran just fine…
had some Sass deprecation warnings but thats about it.
Whats going on here?!
