How does one debug a netlify build issue?
I check in my code to GitHub, triggers netlify to build\deploy. But it fails, and the logs don’t seem to give me much…
This is where it kinda tanks. All works\builds on the Mac, netlify cli…
10:39:49 AM: Started restoring cached node modules
10:39:49 AM: Finished restoring cached node modules
10:39:50 AM: Installing NPM modules using NPM version 6.13.4
10:40:13 AM: npm
10:40:13 AM: WARN deprecated
10:40:13 AM: core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
10:41:01 AM: npm WARN
10:41:01 AM: rm not removing /opt/build/repo/node_modules/.bin/uglifyjs as it wasn’t installed by /opt/build/repo/node_modules/uglify-js
10:41:01 AM: npm WARN rm not removing /opt/build/repo/node_modules/.bin/semver as it wasn’t installed by /opt/build/repo/node_modules/semver
10:41:01 AM: rm not removing /opt/build/repo/node_modules/.bin/regjsparser as it wasn’t installed by /opt/build/repo/node_modules/regjsparser
10:41:01 AM: npm WARN rm not removing /opt/build/repo/node_modules/.bin/pbjs as it wasn’t installed by /opt/build/repo/node_modules/protobufjs
10:41:01 AM: rm not removing /opt/build/repo/node_modules/.bin/nopt as it wasn’t installed by /opt/build/repo/node_modules/nopt
10:41:01 AM: npm WARN rm not removing /opt/build/repo/node_modules/.bin/json5 as it wasn’t installed by /opt/build/repo/node_modules/json5
10:41:01 AM: rm not removing /opt/build/repo/node_modules/.bin/jsesc as it wasn’t installed by /opt/build/repo/node_modules/jsesc
10:41:01 AM: npm
10:41:01 AM: WARN rm not removing /opt/build/repo/node_modules/.bin/esparse as it wasn’t installed by /opt/build/repo/node_modules/esprima
10:41:01 AM: not removing /opt/build/repo/node_modules/.bin/esvalidate as it wasn’t installed by /opt/build/repo/node_modules/esprima
10:41:01 AM: npm WARN rm not removing /opt/build/repo/node_modules/.bin/cssesc as it wasn’t installed by /opt/build/repo/node_modules/cssesc
10:41:12 AM: > grpc@1.24.2 install /opt/build/repo/node_modules/grpc
10:41:12 AM: > node-pre-gyp install --fallback-to-build --library=static_library
10:41:12 AM: sh: 1: node-pre-gyp: not found
10:41:14 AM: failed during stage ‘building site’: Build script returned non-zero exit code: 1
10:41:14 AM: npm WARN bootstrap@4.4.1 requires a peer of jquery@1.9.1 - 3 but none is installed. You must install peer dependencies yourself.
10:41:15 AM: Shutting down logging, 25 messages pending
hi there,
we had a temporary issue this morning that affected some of our services - this may be related. Are you still seeing this problem?
If not, this post is a good general guide to debugging:
Let us know how it goes!
