Hey @Scott thank you so much. I don’t want to take much of your time so I’ll be as concise as possible.
I just realized I might have accidently messed up this sample links while testing things.
The github repo link changed, so I moved the test one I used for this gitlab repo here
https://gitlab.com/santiyounger/santi-website-netlify-test
The other links above to my test sites should work now.
The problem is that this section:
notes sub folder (secondary theme doesn’t work at all)
https://santi-test-1.netlify.app/notes/
Should look like this one:
notes sub-folder (secondary theme)
https://santi-test-2.netlify.app/notes/
Side note: the css sometimes breaks, once I fix this, it should look like this example using this theme
The Main Problem
Netlify doesn’t seem to consider my public directory when deploying with git, since I’m using config-notes.toml to export the /notes subpage of my site to be built with a secondary theme.
then I build it all to the hugo public directory, it work when dragging and droppin the “public directory” to netlify, but netlify doesn’t read the secondary theme when deployed with git, it seems to ignore the public directory.
my guess is I must have something missing in my netlify.toml
Deploy Log
I’ll attach here netlify’s deploy log. (I’m sorry, I’m not sure if this is what you asked for when you said “build log” let me know if you need something else)
Santi test 1 Deploy Log (Build From Gitlab)
Summary
5:46:05 PM: Build ready to start
5:46:06 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
5:46:06 PM: build-image tag: v3.4.1
5:46:06 PM: buildbot version: e1f4178b0d9779ebad1b11d5b54739f82fed3c22
5:46:07 PM: Fetching cached dependencies
5:46:07 PM: Starting to download cache of 99.0MB
5:46:09 PM: Finished downloading cache in 2.049797014s
5:46:09 PM: Starting to extract cache
5:46:12 PM: Finished extracting cache in 3.543649114s
5:46:12 PM: Finished fetching cache in 5.628136832s
5:46:12 PM: Starting to prepare the repo for build
5:46:13 PM: Preparing Git Reference refs/heads/master
5:46:15 PM: Starting build script
5:46:15 PM: Installing dependencies
5:46:15 PM: Python version set to 2.7
5:46:15 PM: Started restoring cached node version
5:46:18 PM: Finished restoring cached node version
5:46:19 PM: v12.18.0 is already installed.
5:46:20 PM: Now using node v12.18.0 (npm v6.14.4)
5:46:20 PM: Started restoring cached build plugins
5:46:20 PM: Finished restoring cached build plugins
5:46:20 PM: Attempting ruby version 2.7.1, read from environment
5:46:22 PM: Using ruby version 2.7.1
5:46:22 PM: Using PHP version 5.6
5:46:22 PM: 5.2 is already installed.
5:46:22 PM: Using Swift version 5.2
5:46:22 PM: Installing Hugo 0.74.3
5:46:23 PM: Hugo Static Site Generator v0.74.3-DA0437B4/extended linux/amd64 BuildDate: 2020-07-23T16:30:30Z
5:46:23 PM: Started restoring cached go cache
5:46:23 PM: Finished restoring cached go cache
5:46:23 PM: go version go1.14.4 linux/amd64
5:46:23 PM: Installing missing commands
5:46:23 PM: Verify run directory
5:46:24 PM:
5:46:24 PM: ┌─────────────────────────────┐
5:46:24 PM: │ Netlify Build │
5:46:24 PM: └─────────────────────────────┘
5:46:24 PM:
5:46:24 PM: ❯ Version
5:46:24 PM: @netlify/build 3.3.5
5:46:24 PM:
5:46:24 PM: ❯ Flags
5:46:24 PM: deployId: 5f54152c213d7800076c4ddd
5:46:24 PM: mode: buildbot
5:46:24 PM:
5:46:24 PM: ❯ Current directory
5:46:24 PM: /opt/build/repo
5:46:24 PM:
5:46:24 PM: ❯ Config file
5:46:24 PM: /opt/build/repo/netlify.toml
5:46:24 PM:
5:46:24 PM: ❯ Context
5:46:24 PM: production
5:46:24 PM:
5:46:24 PM: ┌────────────────────────────────────┐
5:46:24 PM: │ 1. build.command from netlify.toml │
5:46:24 PM: └────────────────────────────────────┘
5:46:24 PM:
5:46:24 PM: hugo --gc --minify
5:46:26 PM: Building sites …
5:46:26 PM: | EN
5:46:26 PM: -------------------+------
5:46:26 PM: Pages | 156
5:46:26 PM: Paginator pages | 69
5:46:26 PM: Non-page files | 0
5:46:26 PM: Static files | 0
5:46:26 PM: Processed images | 0
5:46:26 PM: Aliases | 11
5:46:26 PM: Sitemaps | 1
5:46:26 PM: Cleaned | 2
5:46:26 PM: Total in 1366 ms
5:46:26 PM:
5:46:26 PM: (build.command completed in 1.5s)
5:46:26 PM:
5:46:26 PM: ┌─────────────────────────────┐
5:46:26 PM: │ Netlify Build Complete │
5:46:26 PM: └─────────────────────────────┘
5:46:26 PM:
5:46:26 PM: (Netlify Build completed in 1.5s)
5:46:26 PM: Caching artifacts
5:46:26 PM: Started saving build plugins
5:46:26 PM: Finished saving build plugins
5:46:26 PM: Started saving pip cache
5:46:26 PM: Finished saving pip cache
5:46:26 PM: Started saving emacs cask dependencies
5:46:26 PM: Finished saving emacs cask dependencies
5:46:26 PM: Started saving maven dependencies
5:46:26 PM: Finished saving maven dependencies
5:46:26 PM: Started savin 5:46:05 PM: Build ready to start
5:46:24 PM:
5:46:24 PM:
5:46:24 PM:
5:46:24 PM: ❯ Flags
5:46:24 PM:
5:46:24 PM:
5:46:24 PM:
5:46:24 PM:
5:46:24 PM:
5:46:26 PM: | EN
5:46:26 PM: -------------------±-----
5:46:26 PM:
5:46:26 PM:
5:46:26 PM:
5:46:26 PM: Started saving boot dependencies
5:46:26 PM: Finished saving boot dependencies
5:46:26 PM: Started saving go dependencies
5:46:26 PM: Finished saving go dependencies
5:46:26 PM: Build script success
5:46:26 PM: Starting to deploy site from ‘public’
5:46:26 PM: Creating deploy tree
5:46:26 PM: Creating deploy upload records
5:46:26 PM: 126 new files to upload
5:46:26 PM: 0 new functions to upload
5:46:29 PM: Starting post processing
5:46:29 PM: Post processing - HTML
5:46:39 PM: Post processing - header rules
5:46:39 PM: Post processing - redirect rules
5:46:39 PM: Post processing done
5:46:39 PM: Site is live
5:46:44 PM: Finished processing build request in 37.948433705sg boot dependencies
Santi Test 2 Deploy Log (drag and dropped public directory)
Summary
11:22:23 AM: Creating deploy upload records
11:22:24 AM: Starting post processing
11:22:24 AM: Post processing - HTML
11:22:26 AM: Post processing - header rules
11:22:26 AM: Post processing - redirect rules
11:22:26 AM: Post processing done
11:22:26 AM: Site is live
Alternatives
I’ve been testing a few different things, I might go for the route of having my /notes page separeate into a subdomain to simpify things, and treating it as a separete hugo site completly.
I don’t want to take much of your time, so if the fix isn’t obvious or easy to fix, don’t worry I still appreciate you having taken the time to look at this, thank you @Scott I really appreciate your help!
