Hello,
I just discovered Netlify and it’s my first time deploying a website. Here is the access to my site: https://sprightly-pika-e45d03.netlify.app/
As you can see, only the HTML is loading and I’m not retrieving the CSS (Tailwind) or my media assets.
I’m using Nuxt3 and here is the link to my Git repository and Git page:
Repository: https://github.com/peahRAR/mma_baisieux
Git page: https://peahrar.github.io/mma_baisieux/
I have no idea why only the HTML is loading. Thank you in advance for your help.
Deploy logs :
12:03:20 AM: Starting post processing
12:03:20 AM: Skipping HTML post processing
12:03:20 AM: Post processing - header rules
12:03:20 AM: Post processing - redirect rules
12:03:20 AM: Post processing done
12:03:20 AM: Section completed: postprocessing
12:03:21 AM: Site is live ![]()
12:03:01 AM: build-image version: d68af4ff92f3d66fc07f4cb4ed7d1649da1994aa (focal)
12:03:01 AM: buildbot version: d68af4ff92f3d66fc07f4cb4ed7d1649da1994aa
12:03:01 AM: Fetching cached dependencies
12:03:01 AM: Starting to download cache of 119.7MB
12:03:01 AM: Finished downloading cache in 379ms
12:03:01 AM: Starting to extract cache
12:03:02 AM: Finished extracting cache in 786ms
12:03:02 AM: Finished fetching cache in 1.231s
12:03:02 AM: Starting to prepare the repo for build
12:03:02 AM: Preparing Git Reference refs/heads/main
12:03:04 AM: Starting to install dependencies
12:03:04 AM: Python version set to 3.8
12:03:04 AM: Attempting Ruby version 2.7.2, read from environment
12:03:04 AM: Using Ruby version 2.7.2
12:03:05 AM: Started restoring cached go cache
12:03:05 AM: Finished restoring cached go cache
12:03:05 AM: go version go1.19.10 linux/amd64
12:03:05 AM: Using PHP version 8.0
12:03:06 AM: Started restoring cached Node.js version
12:03:06 AM: Finished restoring cached Node.js version
12:03:07 AM: v18.16.1 is already installed.
12:03:07 AM: Now using node v18.16.1 (npm v9.5.1)
12:03:07 AM: Enabling Node.js Corepack
12:03:07 AM: Started restoring cached build plugins
12:03:07 AM: Finished restoring cached build plugins
12:03:07 AM: Started restoring cached corepack dependencies
12:03:07 AM: Finished restoring cached corepack dependencies
12:03:07 AM: No npm workspaces detected
12:03:07 AM: Started restoring cached node modules
12:03:07 AM: Finished restoring cached node modules
12:03:07 AM: Installing npm packages using npm version 9.5.1
12:03:10 AM: > postinstall
12:03:10 AM: > nuxt prepare
12:03:10 AM: [log] Nuxi 3.4.3
12:03:11 AM: [success] Types generated in .nuxt
12:03:11 AM: up to date, audited 645 packages in 4s
12:03:11 AM: 99 packages are looking for funding
12:03:11 AM: run npm fund for details
12:03:11 AM: 18 vulnerabilities (17 moderate, 1 high)
12:03:11 AM: To address issues that do not require attention, run:
12:03:11 AM: npm audit fix
12:03:11 AM: To address all issues (including breaking changes), run:
12:03:11 AM: npm audit fix --force
12:03:11 AM: Run npm audit for details.
12:03:11 AM: npm packages installed
12:03:12 AM: Install dependencies script success
12:03:12 AM: Starting build script
12:03:13 AM: Detected 1 framework(s)
12:03:13 AM: nuxt at version 3.4.3
12:03:13 AM: Section completed: initializing
12:03:14 AM:
12:03:14 AM: Netlify Build
12:03:14 AM: ────────────────────────────────────────────────────────────────
12:03:14 AM:
12:03:14 AM: ❯ Version
12:03:14 AM: @netlify/build 29.15.0
12:03:14 AM:
12:03:14 AM: ❯ Flags
12:03:14 AM: baseRelDir: true
12:03:14 AM: buildId: 64a34593967a46636a58ed46
12:03:14 AM: deployId: 64a34593967a46636a58ed48
12:03:14 AM:
12:03:14 AM: ❯ Current directory
12:03:14 AM: /opt/build/repo
12:03:14 AM:
12:03:14 AM: ❯ Config file
12:03:14 AM: No config file was defined: using default values.
12:03:14 AM:
12:03:14 AM: ❯ Context
12:03:14 AM: production
12:03:14 AM:
12:03:14 AM: Build command from Netlify app
12:03:14 AM:
12:03:14 AM: $ nuxt generate
12:03:14 AM: [log] Nuxi 3.4.3
12:03:14 AM: [log] Nuxt 3.4.3 with Nitro 2.4.0
12:03:15 AM: [warn] Using experimental payload extraction for full-static output. You can opt-out by setting experimental.payloadExtraction to false.
12:03:16 AM: [info] Building client…
12:03:16 AM: [info] vite v4.3.6 building for production…
12:03:16 AM: [info] transforming…
12:03:18 AM: [info] ✓ 130 modules transformed.
12:03:18 AM: [info] rendering chunks…
12:03:18 AM: [info] computing gzip size…
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/default-logo.5d65c4a2.png 5.45 kB
12:03:18 AM: [info] .nuxt/dist/client/manifest.json 7.43 kB │ gzip: 0.98 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/profil-placeholder.de7b2bce.webp 7.84 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/Inter-400-5.ac4e131c.woff2 8.64 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/size-retina-logo.380171be.png 9.69 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/Inter-400-3.fe977ddb.woff2 11.95 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/Inter-400-2.262a1054.woff2 17.08 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/Inter-400-4.89b4a3fe.woff2 22.00 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/Inter-400-1.848492d3.woff2 26.69 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/Inter-400-7.450f3ba4.woff2 37.92 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/Inter-400-6.45606f83.woff2 56.97 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/full-logo.10615547.png 60.60 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/forkawesome-webfont.8810ba34.woff2 109.92 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/espaceSR.7b6115ac.webp 111.48 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/forkawesome-webfont.006708d6.woff 136.12 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/forkawesome-webfont.4f319287.ttf 219.00 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/forkawesome-webfont.62c52951.eot 219.19 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/forkawesome-webfont.d491dbcb.svg 560.55 kB │ gzip: 187.73 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/bg-red.b54a80e9.jpg 3,613.26 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/hero-fight.92be095c.mp4 12,064.35 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/error-500.aa16ed4d.css 1.95 kB │ gzip: 0.74 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/error-404.23f2309d.css 3.63 kB │ gzip: 1.12 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/entry.a501e518.css 51.13 kB │ gzip: 13.16 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/error-component.1fbb60b9.js 1.12 kB │ gzip: 0.61 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/error-500.e83bafe1.js 1.88 kB │ gzip: 0.99 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/error-404.36b073b5.js 6.50 kB │ gzip: 2.88 kB
12:03:18 AM: [info] .nuxt/dist/client/_nuxt/entry.092139c8.js 160.72 kB │ gzip: 59.77 kB
12:03:18 AM: [info] ✓ built in 2.06s
12:03:18 AM: [success] Client built in 2064ms
12:03:18 AM: [info] Building server…
12:03:18 AM: [info] vite v4.3.6 building SSR bundle for production…
12:03:18 AM: [info] transforming…
12:03:19 AM: [info] ✓ 86 modules transformed.
12:03:19 AM: [info] rendering chunks…
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/error-404-styles.a5c3f351.mjs 0.08 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/error-500-styles.6b5b5ff2.mjs 0.08 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/CoachTeam-styles.513ea46e.mjs 0.08 kB
12:03:19 AM: [info] .nuxt/dist/server/styles.mjs 0.46 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/index-e12b288f.js 0.22 kB │ map: 5.28 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/CoachTeam-styles-1.mjs-1f475dbe.js 0.39 kB │ map: 0.12 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/island-renderer-b43416dd.js 1.10 kB │ map: 1.32 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/error-component-2dddb876.js 2.01 kB │ map: 2.66 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/error-500-styles-1.mjs-0a86f27a.js 2.17 kB │ map: 0.12 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/error-dev-styles-1.mjs-90bc7cbc.js 2.46 kB │ map: 0.12 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/error-500-cfdfb70c.js 3.13 kB │ map: 3.79 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/css-styles-3.mjs-e46b06d6.js 3.68 kB │ map: 0.11 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/error-404-styles-1.mjs-6ef6e240.js 3.86 kB │ map: 0.12 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/error-404-b9b51ff9.js 9.75 kB │ map: 18.88 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/css-styles-1.mjs-9c84f993.js 14.86 kB │ map: 0.11 kB
12:03:19 AM: [info] .nuxt/dist/server/_nuxt/css-styles-2.mjs-e92de74b.js 37.36 kB │ map: 0.11 kB
12:03:19 AM: [info] .nuxt/dist/server/server.mjs 49.22 kB │ map: 81.64 kB
12:03:19 AM: [info] ✓ built in 1.03s
12:03:19 AM: [success] Server built in 1039ms
12:03:19 AM: [success] [nitro] Generated public dist
12:03:19 AM: [info] [nitro] Initializing prerenderer
12:03:19 AM: [info] [nitro] Prerendering 4 initial routes with crawler
12:03:19 AM: [log] [nitro] ├─ / (30ms)
12:03:19 AM: [log] [nitro] ├─ /test-page (4ms)
12:03:19 AM: [log] [nitro] ├─ /200.html (2ms)
12:03:19 AM: [log] [nitro] ├─ /404.html (1ms)
12:03:19 AM: [log] [nitro] ├─ /_payload.js (1ms)
12:03:19 AM: [log] [nitro] ├─ /test-page/_payload.js (0ms)
12:03:19 AM: [success] You can now deploy dist to any static hosting!
12:03:19 AM:
12:03:19 AM: (build.command completed in 5.4s)
12:03:19 AM:
12:03:19 AM: Functions bundling
12:03:19 AM: ────────────────────────────────────────────────────────────────
12:03:19 AM:
12:03:19 AM:
12:03:19 AM: (Functions bundling completed in 3ms)
12:03:19 AM:
12:03:19 AM: Deploy site
12:03:19 AM:
12:03:19 AM: Starting to deploy site from ‘dist’
12:03:19 AM: Calculating files to upload
12:03:20 AM: 4 new files to upload
12:03:20 AM: 0 new functions to upload
12:03:20 AM: Section completed: deploying
12:03:20 AM: Site deploy was successfully initiated
12:03:20 AM:
12:03:20 AM: (Deploy site completed in 380ms)
12:03:20 AM:
12:03:20 AM: Netlify Build Complete
12:03:20 AM: ────────────────────────────────────────────────────────────────
12:03:20 AM:
12:03:20 AM: (Netlify Build completed in 5.8s)
12:03:20 AM: Caching artifacts
12:03:20 AM: Started saving node modules
12:03:20 AM: Finished saving node modules
12:03:20 AM: Started saving build plugins
12:03:20 AM: Finished saving build plugins
12:03:20 AM: Started saving corepack cache
12:03:20 AM: Finished saving corepack cache
12:03:20 AM: Started saving pip cache
12:03:20 AM: Finished saving pip cache
12:03:20 AM: Started saving emacs cask dependencies
12:03:20 AM: Finished saving emacs cask dependencies
12:03:20 AM: Started saving maven dependencies
12:03:20 AM: Finished saving maven dependencies
12:03:20 AM: Started saving boot dependencies
12:03:20 AM: Finished saving boot dependencies
12:03:20 AM: Started saving rust rustup cache
12:03:20 AM: Finished saving rust rustup cache
12:03:20 AM: Started saving go dependencies
12:03:20 AM: Finished saving go dependencies
12:03:20 AM: Build script success
12:03:20 AM: Section completed: building
12:03:21 AM: Uploading Cache of size 119.5MB
12:03:22 AM: Section completed: cleanup
12:03:22 AM: Finished processing build request in 21.355s
