If you mean that you want to check if user has filled the reCaptcha before allowing to submit the form, then it’s possible in JS (client-side). Something like this: javascript - How to check in js that user has checked the checkbox in Google recaptcha? - Stack Overflow. So if you’ve already setup everything with Firebase, you need to migrate your setup to Netlify. However, if you’ve not setup anything yet, RBAC might help.
Related topics
Topic | Replies | Views | Activity | |
I'd like my form to bypass the dashboard and just send an email | 2 | 340 | July 27, 2021 | |
Skip form fields while sending netlify form via web hook to external links | 1 | 477 | June 8, 2021 | |
Password protection / basic auth not working with forms+ lambda | 2 | 729 | September 15, 2020 | |
Form stopped working after testing honeypot and captcha | 4 | 20 | January 10, 2025 | |
Post to Netlify function behind basic password protection | 4 | 1032 | July 6, 2023 |
