Images won't load on deployed site
I’ve been using Netlify and Zola for my website for a couple years now and haven’t had an issue until today. 2 images won’t load ‘/images/SanDiego2023.jpg’ and ‘image/Austin2022.jpg’ they’re in the same folder as other images that are loading. When I inspect the images in the browser the link to them looks correct and it’s the same as the images that are loading.
my github url is : GitHub - mkemorgn/mkemorgn.com: Source code for my website.
the offending page on my website is : Mike Morgan
the images are in my git hub repo here https://github.com/mkemorgn/mkemorgn.com/tree/master/public/images
I also noticed in my build logs that netlify says it detected 2 frame works: Hugo and Zola. I’ve never used Hugo so I’m not sure where that’s coming from? Not sure if that has anything to do with this, I looked at old deploy logs and didn’t see that. This is the first time I’ve deployed in about 6 months.
@mkemorgn You have added your new images to the /public/images/ folder in your repository, which is likely your site output.
Add them to /static/images/ instead.
Your build will be emptying the public folder, so you could exclude it from your repository entirely using .gitignore to prevent confusion.
Nice! Thanks for this.
