Images not showing in 3rd party carousel
Hi there!
I am using a 3rd party carousel (vueper slide ) and when i host it locally all my pictures in the carousel shows up.
However when i deploy it on netlify (https://timberjack.netlify.app/) the pictures do not show up in the about section. (TimberJack Tree Services). I do not believe that the problem would arise from the carousel itself, because on home page I do use it for hard coded google reviews that shows up just fine.
So probably path issue? This is how I have been trying to implement it: slides: [
image: ‘/img/20.png’,
Thank you in advance!
@alig It looks like you’ve resolved this yourself, great work.
If seeking assistance with anything similar in the future, instead of just a description, you should provide access to either the source code or a minimum reproduction.
hi, I also have the same problem
@nLucas011, the previous advise:
…still holds true.
