I need advice to debug deploy https://app.netlify.com/sites/practical-mcnulty-83e18a/deploys/5f2689a3bc72d8e9a74fb498
Hey Kenny,
It’s saying that react-router-dom is not installed, have you installed the package?
yeah i have. But it keeps showing the error
Package.json
“name”: “little-rock”,
“version”: “0.1.0”,
“private”: true,
“dependencies”: {
"@material-ui/core": "^4.10.2",
"@material-ui/icons": "^4.9.1",
"@material-ui/styles": "^4.10.0",
"@testing-library/jest-dom": "^4.2.4",
"@testing-library/react": "^9.5.0",
"@testing-library/user-event": "^7.2.1",
"bootstrap": "^4.5.0",
"google-maps-react": "^2.0.6",
"grommet": "^2.14.0",
"grommet-icons": "^4.4.0",
"grommet-styles": "^0.2.0",
"polished": "^3.6.5",
"react": "^16.13.1",
"react-bootstrap": "^1.0.1",
"react-dom": "^16.13.1",
"react-router": "^5.2.0",
"react-router-dom": "^5.2.0",
"react-scripts": "3.4.1",
"semantic-ui-react": "^0.88.2",
"styled-components": "^5.1.1"
“scripts”: {
"start": "react-scripts start",
"build": "react-scripts build",
"test": "react-scripts test",
"eject": "react-scripts eject"
“eslintConfig”: {
"extends": "react-app"
“browserslist”: {
"production": [
">0.2%",
"not dead",
"not op_mini all"
"development": [
"last 1 chrome version",
"last 1 firefox version",
"last 1 safari version"
Hi @kennymanman,
Please don’t multi-post the same concern. It makes it harder for us to see your progress.
I agree with Joshua above, as I also posted here. You’ll need to ensure that you’re installing the dependency correctly.
